[Solved] Touran 1.9 2005: Engine Turns On/Off, No Start - Battery, Relay 458, Fuses & Steering Issues
lukaszek356 17064 2
  • #1 17209925
    lukaszek356
    Rate: 8
    Hello, I have a problem with Touran namely the car turns but does not start. Yesterday my dad was looking at the hook nest, because only the parking lot lights came out, maybe that was the reason. Today the car did not want to start, the battery fell. We connected the battery to the rectifier, there was also a test for cables, it turns everything ok, but it doesn't start. If this has something to do with Stop and electromechanical power steering indicator, ignition assist works ok. Checked fuses with everything ok. Is relay 458? is not tarnished but maybe burned? Dad said he was putting some fuses in the free places, maybe he put some fuse somewhere? Which fuses from the added photo list are responsible for ignition, fuel system etc.? Maybe some driver has fallen? I am waiting and thank you in advance for your answers
    Touran 1.9 2005: Engine Turns On/Off, No Start - Battery, Relay 458, Fuses & Steering Issues Touran 1.9 2005: Engine Turns On/Off, No Start - Battery, Relay 458, Fuses & Steering Issues
  • #2 17210288
    kowal5
    Help: 25
    Rate: 69
    The support light is on because the battery was discharged and now needs a steering angle sensor calibration, but you will calibrate it yourself when you start it. For the rest, you have not provided enough information from your own work to be able to help you.
  • #3 17211373
    lukaszek356
    Rate: 8
    It turned out that the fuses were mixed up, as dad looked at the hook, he took out one of the fuses responsible for immo. After coming to order, where everything is supposed to be, everything has returned to normal.
