DAF XF 105.41O: Issue with Horse & Trailer Stop, Fuse 36, Relay Ticks, Pin 56c, Cable No. 4601
PAWEX7X 14370 4
  • #1 16214261
    PAWEX7X
    Rate: 11
    Daf xf 105.410 no stop in the horse and trailer, fuse 36 checked the current in it, the relay ticks. The service gave pin 56c: 12 cable No. 4601 to check and give it a plus - it lights up the position under this pin. Does anyone have any idea ??? Please help
  • #2 16215336
    citromaniak
    Help: 53
    Rate: 389
    And the stop sensor under the brake pedal functional?
  • #3 16215453
    klika60
    Help: 20
    Rate: 278
    And if you press stop, the position does not light up? Check if there is a plus on the relay, pin 30, if it is a pin 30 bridge with pin 87, everything is described on the relays, if the fault of the relay lights up, if not the beam under the cabin. Alternatively, check the relay control
  • #4 17233053
    goldenarts
    Hello, I have just lighting up the position after pressing the stop ... please help ... Rafał
  • #5 17233155
    citromaniak
    Help: 53
    Rate: 389
    Compact pros, two are wrong cables in the rear lamp plug
