Daf 105 460 (2011 Model) - Central Vehicle Control Device Error Post Exhaust Hose Connection
eleczek 13821 2
  • #1 16721682
    eleczek
    Rate: 15
    I know that the topic was similar, but not quite the same as for me. Daf is my new car, 2011.
    I tried to connect the exhaust hose in the cabin, and unfortunately, as it turned out later, I inserted the end into the electric wire under the driver's seat, the one next to the pilot. It sparked and the error crashed "Central vehicle control device error".
    I checked the fuses, they are all ok, I also bought a relay, replaced them with all of them and still nothing. Or maybe someone knows where the cause may be? Apart from the message, everything works.
  • #2 16722448
    kisiol
    Help: 36
    Rate: 469
    you checked if there is power in this connector.
  • #3 16738663
    eleczek
    Rate: 15
    Problem solved. This short circuit under the driver's seat blasted the fuse from the heating of the seat. Thank you for your interest.
