Opel Vectra 1.9 CDTI Z19DT Engine Oil Change - Capacity & Recommendations
da19we 37944 10
How much oil does a 1.9 CDTI Z19DT engine take during an oil change?
A 1.9 CDTI/Z19DT engine takes about 4.3 liters of oil with the filter changed, and one user noted it is a little over 4 liters with 5W-30 [#16943692][#16943916][#16941942] It is also worth checking an oil producer’s configurator for the exact quantity for your engine code [#16941579]
  • #1 16941540
    da19we
    Rate: 17
    Hello, I would like to know how much oil to enter 1.9CDTI-Z19DT engine
    I will remove it as soon as I find out :)
    Alfred_92
    Help: 148
    Rate: 708
    Check the pages of oil producers, in the configurators give quantities.
  • #3 16941615
    da19we
    Rate: 17
    Thank you buddy :) I did not even think about it :) Greetings
  • #4 16941942
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    I once had Zafira with this engine. It goes a little over 4 liters 5w30.
  • #5 16943692
    kokosz1981
    Rate: 20
    All 3 varieties 1.9 theoretically swallow 4.3 liters with filter change
    The min-max bay is 0.7 liters
  • #6 16943916
    milejow
    Help: 1566
    Rate: 5160
    kokosz1981 wrote:
    4.3 liters with filter replacement
    Exactly.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #7 17537498
    robson079
    Help: 12
    Rate: 64
    Hello! I have to exchange oil in Vectra C 1.9 CDTI 120 km without DPF theoretically run 300,000. Currently, it is flooded with ELF 5W / 40 oil. From the change to the change, i.e. around 15,000, it will go down from the ruler but I will not top it up. The problem is that the turbo is all wet and very wet, including the bottom of the engine, but the sequence is correct and silent. The engine works a little louder because I have a comparison because my friend has a car with this engine. I want to pour motor oil MOTUL SYNERGIE + 6100 10W40. The question is I going in the right direction?
  • #8 17537623
    tadkli9743
    Help: 70
    Rate: 280
    That 10W40 is going in the right direction because with this course a thicker oil is recommended.
  • #9 17538169
    4495redberet
    Help: 110
    Rate: 348
    In what good direction !! ??
    Eliminate the leak and pour as best oil as you did not sleep. Probably the loss is just a leak. Do not torture the engines with any gestures. So in the understanding of what a larger leak is the "thicker" oil ???? So what's the last stage of this towot ??
  • #10 17538232
    robson079
    Help: 12
    Rate: 64
    OK turbo I can regenerate and what about the louder engine work? The noise comes from the head as if the camshaft was making a noise. Flooding the oil down is probably not a killing for the engine.
  • #11 17538322
    4495redberet
    Help: 110
    Rate: 348
    If you have something worked out, the thicker oil will not do much good, and as it probably is for a moment. Such symptoms are the driller's wholesaler. It is best to check what causes such noises, because maybe something will fall apart in a moment.
The discussion centers around the oil change for the Opel Vectra 1.9 CDTI Z19DT engine. Users inquire about the oil capacity, with responses indicating that the engine typically requires around 4.3 liters of oil when changing the filter, with a minimum-maximum variation of 0.7 liters. Recommendations for oil types include 5W30 and 10W40, with some users discussing their experiences with different oil brands and the importance of addressing any leaks before changing oil. Concerns about engine noise and turbo issues are also raised, emphasizing the need for proper maintenance and potential repairs.
