Citroen C3 2003 1.4HDi - Horn and windshield washer not working
bolekf2 12777 2
  • #1 16215725
    bolekf2
    Rate: 258
    Hello, I write about the car as a topic.
    The front, rear and horn washer systems do not work in the car. When the washer is switched on, the wipers switch on but the washer motor does not control. The horn doesn't work either.
    The fuses are of course functional.
    During diagnostics, in the parameters, the switch module under the steering wheel sees when we press the horn as well as the front and rear washer.
    BSI also sees when we press the horn and washer.
    The BSM module remains under the hood, there is no contact with it, generally, because it is probably just an executive system. In Lexia, you don't even have to choose this module.
    The second BSM module was ordered, after connecting the same situation, so BSM rather falls off.
    The weight at the horn, of course, is, but the horn does not control the BSM. In BSM, the green 16pin plug, pin 15 is the horn control.
    There are also two masses on the pins with the washer motor, but when we turn on the washer, no control appears on any of the two pins, there are still two masses. BSM harness, green 16pin plug, pin 14 and 11 are connected to the washer motor.
    I have a question, does BSI control BSM, horn and washer, via the Van network or through ordinary signals?
    If the BSM under the bonnet has been replaced, does this clearly indicate damage to the BSI itself?
  • #3 16215911
    bolekf2
    Rate: 258
    Yes, the horn and the pump work for a short time, when giving a signal on the disconnected BSM plug to the pins I mentioned.
    For the pump, after applying to the pins 14 and 11 of the plug, "+" and "-", depending on how we give the signals, the sprayer works from the front or rear.
    For the horn (Pin 15 is bridged in BSM with pin 7), after giving the "+" signal on the disconnected plug, on the pin 15 of the plug, the horn works.
    Since in the parameters, in the switches under the steering wheel of the com2000 and in the BSI, he sees the activation of the horn and the washer, and the BSM has been changed to another one, with no effect, then probably the BSI is replaced, which, despite noticing the control, does not send a signal to BSM, do I think?
