Citroën C1 2013 1.0 Engine: Headlights Not Working, Dipped Beam, Main-fuses, DRL LEDs, H4 Bulbs
mars991 14877 8
  • Headlight relay box under left lamp may be missing relays
    #1 16483865
    mars991
    Rate: 15
    Help me because my hands are literally falling :-(
    The car is a Citroen C1 with 1.0 engine from 2013.
    Colleagues have stopped lighting headlights (passing and driving lights) parking lots are lit, daytime running LEDs also light up after starting the engine. After turning the control handle to the passing position, the leds go out and the "short-K" and "long-D" indicators appear on the clock at once, switching K / D gives nothing and no physical lights. The fuses are checked, all the ones in the engine compartment and the clock, I have dismantled the steering wheel and the combined switch, the socket-plug is checked and it's OK. I disassembled the switch and the contacts in it are also OK, all the relays under the dashboard checked, some replaced because most are the same. H4 bulbs were listed first and are functional. I found a box under the left headlight in which, according to the illustration found on the internet, there should be relays from the daytime running lights / passing beam and a few other from the engine components and I found in it only one socket with a relay that lights the leds, prophylactically replaced it with the same from the cockpit but nothing changed.
  • #2 16483889
    piotrekwoj1
    Help: 947
    Rate: 3433
    You need to do a peugeot planet diagnosis and view the actual values. You will see how it reacts to the shift of the handle.
  • #3 16483904
    mars991
    Rate: 15
    So you suggest that the problem may be in the handle?
  • #4 16483928
    g107r
    Help: 811
    Rate: 993
    Have you checked whether the bulbs have a plus and minus supply?
    Maybe everything on the "turn on" side is ok, and there is no other pole, for example, a hypothetical common ground when powered by plus bulbs?
  • #5 16484010
    mars991
    Rate: 15
    I checked the ankle and there is mass in it and there is no +12 at the short or long junction.
    Added after 6 [minutes]:
    I remembered that after disconnecting the cubes from both bulbs after turning the handle, the lights in the clock appear separately depending on the position of the handle, which is how it should be.
  • #6 16484073
    g107r
    Help: 811
    Rate: 993
    What did you check the weight? +12 suggests the meter, check it with a light bulb, the meter does not consume as much power as the light bulb and can be misleading if the connections are poor. The voltage is, but with a minimum current insufficient to light the bulb.
    What you wrote back now and in the first post
    mars991 wrote:
    After turning the handle to the passing position, the leds go out and the "short-K" and "long-D" lights appear on the clock at once
    reminds me vividly of the so-called "Christmas tree" on lamps, usually rear lights, and lack of weight.
    I don't know if it can be applied to these controls in the meter - probably in an "electronic" car, but :?:
    http://c1aygo107.net/index.php?topic=9366.0 have you seen it? The first one popped up, it's probably like that :cry:
  • #7 16484356
    mars991
    Rate: 15
    I have a multimeter but I checked it with a 21W bulb. I read the post from the link but my fault is not described.
  • #8 16484682
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    Maybe BSM?
    He performs the executive function, and BSI sends orders.
    And since the lights are on, BSI receives information from the handle.
    It's best to connect Lexie anyway. Because there you can do tests from your computer. Fire up lights, horn, etc. without moving the control handle.
  • #9 16485502
    mars991
    Rate: 15
    I was at electronics today and it turned out that it was just damaged BSM and was not surprised at all because he saw that the car is after a collision. He claims it can be fixed, we'll see ...
    Thank you all for your interest and best regards.
    Subject to close.
The discussion revolves around a 2013 Citroën C1 with a 1.0 engine experiencing non-functional headlights, including both dipped beam and main beams. The user has checked various components, including fuses, the combined switch, and H4 bulbs, but the issue persists. Responses suggest performing a Peugeot Planet diagnosis to assess the control handle's functionality and checking for proper voltage supply to the bulbs. A multimeter was used for testing, but it was noted that a light bulb should be used for more accurate results. Ultimately, it was determined that a damaged BSM (Bandeau de Services Multiples) was the cause of the problem, which could potentially be repaired.
