Cyfrowy Polsat - Persistent Interference with HD 5500s Decoder Despite Strong Signal
mendos4 8019 9
Why do I still get interference on my HD 5500s decoder despite a strong signal, a new 90 cm antenna, new converter, new Triset-113 cable and properly made connectors?
The most likely cause is a faulty decoder, and in this thread the problem was solved by replacing it [#16217784][#16220283] A good way to verify this is to connect the decoder with a SCART cable or swap it for a known-good unit and see whether the interference disappears [#16217619][#16217784] Before replacing it, also check whether an LTE/router/mobile transmitter is nearby and move the decoder away from it, and recheck the F connectors for any short or bad contact [#16217584] In the reported case, after the decoder was replaced, everything worked normally [#16220283]
  • #1 16217486
    mendos4
    Rate: 15
    Hello. The reception parameters are in the film:
    I don't know how to deal with the noise seen in the movie. I have a new 90 cm antenna, new converter, new 7 m Triset -113 cable, F connectors Cabelcom. HD 5500s decoder. After switching to the Astra it is the same - just as strong signal parameters and identical interference. I will be grateful for suggestions.
  • #2 16217584
  • #3 16217619
  • #4 16217647
    tadkli9743
    Help: 70
    Rate: 280
    My HD 6000 decoder began to interfere with the reception of programs and specifically white stripes flew in the lower part of the screen and the sound was weaker about 50%.
    I took the decoder to the Cyfrowy Polsat showroom without having to replace the decoder with a new one.
    Now works smoothly.
  • #5 16217707
  • #6 16217716
    mendos4
    Rate: 15
    As for the HDMI cable, after connecting the second one is the same. F connectors are also properly made. I don't use LTE but I'm not sure about the neighbors. Several WiFi can be detected in the block.
  • #7 16217736
  • #8 16217768
    mendos4
    Rate: 15
    I understand that if after connecting the SCARTEM interference it will not be the decoder's fault. Or vice versa?
  • #10 16220283
    mendos4
    Rate: 15
    Problem diagnosed. Fallen decoder. After replacement, everything is OK
The discussion revolves around persistent interference issues with the HD 5500s decoder from Cyfrowy Polsat, despite having a strong signal. The user reports using a new 90 cm antenna, a new converter, and a 7 m Triset-113 cable with F connectors. Suggestions from other users include checking for nearby LTE routers that may cause interference, ensuring proper connections and cable integrity, and testing the decoder with a SCART cable to determine if the issue lies with the decoder itself. A follow-up reveals that the problem was diagnosed as a faulty decoder, which was replaced, resolving the interference issue.
