No Signal Issue on One of Two Cyfrowy Polsat Decoders: Antenna or HD5000 Decoder?
FragManiac 13695 9
  • #1 17074343
    FragManiac
    Good morning,
    He writes here because I didn't find help in Cyfrowy Polsat.
    We have two set-top boxes from digital Polsat at home. They are connected to one antenna via a twin convector.
    There was a problem on one decoder a few days ago. Some channels have no signal at all, previously it was very good.
    The decoder from my room works on both connectors, the range is very good. However, the second decoder has no signal on any connector.
    After calls to Polsat we replaced the decoder with a new one, but it did not help. They want us to replace the decoder again.
    Does anyone know what the problem may be? Decoder or antenna?
    POLSAT HD5000 DIGITAL DECODER
  • #2 17074380
    badyl00
    Level 30  
    Help: 221
    Rate: 300
    If on one decoder there is a signal on both sockets and on the other it is not obviously the decoder. And what about the settings in the menu? Maybe a mouth reset. Factory?
  • #3 17074390
    DiZMar
    Help: 2878
    Rate: 6571
    Exchange it. If the second one works from the same socket, it is obviously the decoder's fault although it is possible that the card is damaged. Just why no signal but ...? Mentioned does not mean functional.
  • #4 17074400
    FragManiac
    I tried, it changed nothing. In addition, we have the current decoder for 3 days. Tomorrow they are still going to replace us with a new one.
    It is strange that sometimes these programs will come up for a few hours - But not all.
    Filmbox channels still have no synglau.
  • #5 17074404
  • #6 17074409
    badyl00
    Level 30  
    Help: 221
    Rate: 300
    When exchanging, let them immediately check at the customer service point if everything is OK.
  • #7 17074410
    DiZMar
    Help: 2878
    Rate: 6571
    mihal2002 wrote:
    DiZMar wrote:
    although the card may be damaged
    And what does the card have for the lack of LNB signal.
    Like nothing but when I had an inactive card, on some channels there was a message about the lack of permissions and on some about the lack of a signal.
  • #8 17074416
  • #9 17074590
    andpol 33
    Help: 507
    Rate: 1137
    Was the decoder replaced with the power supply? Because some people only take a decoder and then there is a surprise that the new one does not work either.
  • #10 17074650
    DiZMar
    Help: 2878
    Rate: 6571
    mihal2002 wrote:
    Like an inactive card, it's a garbage decoder. And the messages can be that even water is lacking figuratively.
    Damaged it can be similar to inactive and the messages can be different as you wrote. The decoder is garbage without an active and functional card. I fully agree with you. Thank you for confirming my assumptions although they do not have to be true.
✨ The discussion revolves around a signal issue with one of two Cyfrowy Polsat HD5000 decoders connected to a single antenna via a twin convector. The user reports that while one decoder functions well, the second decoder has no signal on any connector, despite replacing it with a new unit. Responses suggest checking the settings, cables, and connectors, as well as the possibility of a damaged card affecting signal reception. Some users recommend verifying the functionality of the new decoder at the service point before leaving. The intermittent signal on certain channels raises concerns about the decoder's reliability and potential issues with the antenna or cabling.
