Hot Bird 6/8/9 Antenna Setup with HD5000 Decoder: Polsat Cyfrowy No Signal Issue
panbubel 3516 3
  • #1 16577842
    panbubel
    I set the antenna to Hot Bird 6/8/9, HD5000 decoder, the power is green - 100% bar, quality - more than half.
    I have channels, it correctly shows the list, teletext and what is currently broadcast, but on each channel there is a message "no signal from the satellite dish ...".
    I'm trying to find anything about it and can't find it.
  • #2 16577862
    _kli_
    Help: 760
    Rate: 1038
    Reset the decoder to its factory (default) settings.
    panbubel wrote:
    HD5000 decoder, the power is green - the bar is 100%, the quality - more than half
    How big is the antenna? What is your MER, e.g. on TVN HD (press and hold the red button for a while - next to the green one)
  • #3 16578000
    LeDy
    Help: 1990
    Rate: 2938
    More than half
    is it green at all? This is on the verge of pickup. You have quality problem.
    Check the signal on individual transponders, not one, you don't know which one. (Manual tuning)
    Hot Bird 6 / 8 / 9
    Before 6 behind 9 ?
  • #4 16578466
