Polar PTL 1019 - The lights are on but the laundry does not turn on
SWIETYTDW 4401 5
  • #1 16513391
    SWIETYTDW
    Hello!
    I have a problem with the Polar PTL 1019 washing machine. It appeared today, and is manifested by the fact that after choosing any program (the LEDs are of course lit), and pressing the "START" button nothing happens ... What could be the problem?
    Thank you in advance for each answer.
    ps the "Service" diode does not light up after all ...
  • #2 16513493
    Kenworth 18
    Help: 2445
    Rate: 3752
    The damper blockade or its control has probably been damaged.
  • #3 16514149
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    How does the start diode behave?
    The corresponding diode would light up.
  • #4 16514407
    nares
    Help: 1515
    Rate: 3387
    SWIETYTDW wrote:
    nothing happens when you press the "START" button
    Set the water drain and wait until the program ends and the door opens.
  • #5 16515819
    SWIETYTDW
    Here is a video of how the washing machine behaves.
    zhudomel
    Help: 1280
    Rate: 3373
    SWIETYTDW wrote:
    after selecting any program (the LEDs are of course lit up), and pressing the "START" button nothing happens
    How is this happening; the "start" LED stops flashing and the "door open" LED starts flashing, which tells you what the problem is.
