Samsung Galaxy S5 Screen Fails to Illuminate Outdoors: Unlock Button, Low Temperatures, New Battery
dzejkobs 7326 13
Why does my Samsung Galaxy S5 screen only flash briefly or stay dark when I press unlock/power outdoors in cold temperatures, even after replacing the battery?
The most likely cause is a loose or poorly attached LCD flex/ribbon connection, not the battery [#16352265][#16394592] Several replies note that on the Galaxy S5 the LCD tape/connector can come loose, and if pressing the upper right corner makes the screen work again, that points to a bad contact there [#16352265][#16394451] The suggested fix is to disassemble the phone, reseat the tape/connector properly, remove the old glue, and reconnect it securely [#16352265][#16395431] You should also check for damage, bending, or signs of moisture, and verify the board and connections [#16351547][#16356555] Because the S5 display assembly is easy to damage, several replies recommend taking it to a service center if you do not have repair experience [#16356555][#16360488]
  • #1 16350089
    dzejkobs
    I have a problem with the Samsung Galaxy S5 phone, it happens that by clicking the unlock button or the start button the screen does not want to fire, there are only millisecond flashes. It usually happens when I go outside, where the temperature is a bit, or even much lower. For example, I had such a situation yesterday, for 2 hours outside I did not want to start the screen, while a moment after coming home it worked as if nothing had happened. I thought it was the fault of the battery, so I bought a new one, but the problem persists, so that's probably not it. Removing the battery and firing the phone again will do nothing if the problem occurs. Has anyone had a similar event, or has any idea what's going on, even if it didn't occur on the same phone model? Every opinion is important to me.
  • #2 16350869
    dernis
    Help: 15
    Rate: 40
    The phone has been repaired or it may have fallen?
  • #3 16351547
    nutergsm
    Help: 1034
    Rate: 1662
    Disassemble the phone and check if it is damaged or if there are any signs of moisture.
  • #4 16352265
    conrad9210
    Help: 83
    Rate: 210
    Hey. In galaxy S5, the lcd tape often comes out. When it goes out, press it lightly (right side from above) - it should surprise. If it did work, it must be removed, slip the tape correctly and glued back. It will work :)
  • #5 16352478
    dernis
    Help: 15
    Rate: 40
    Alternatively, the flex tape, which is welded by the hot bar, could have peeled off ... but start from scratch first. Check connections, correct connection, etc.
  • #6 16355776
    luk90
    Help: 8
    Rate: 24
    The tape is attached to the push-in connector and not to the connector.
    It looks like an already opened phone and poorly glued.
  • #7 16356227
    dzejkobs
    I have a new phone call, it has never been taken down. He fell in his career several times, but his behavior happened not after the fall, but suddenly.
    Added after 37 [seconds]:
    How should I check it?
  • #8 16356555
    nutergsm
    Help: 1034
    Rate: 1662
    You take your phone apart and check if the tape is securely attached or damaged. You also check if the board itself is not bent, there are no mechanical damages.
    In your place, however, I would give the phone to the service, because you can do more damage yourself.
  • #9 16360488
    luk90
    Help: 8
    Rate: 24
    At S5, sir, do not go without experience.
    It is easy to damage a very expensive display.
  • #10 16361499
    bogdan2491
    Help: 52
    Rate: 96
    Just as luk90 writes, it's better not to move without experience.
    How do you press the glass bends, is it stiff?
    By the way, I had the S5 quite recently which came to me quickly - according to the customer, I never undressed, bought in the salon. It turned out that fast was already made, and in addition at LOCA.
  • #11 16394451
    dzejkobs
    Fast is stiff. After firmly pressing the upper right corner, the problem disappears.
  • #12 16394592
    bogdan2491
    Help: 52
    Rate: 96
    Either the tape is sticking or the problem with the contacts in the display connection with the motherboard, anyway you have to disassemble. As you have never done before, entrust it to a specialist
  • #13 16395431
    luk90
    Help: 8
    Rate: 24
    As I mentioned, raise the fullset, remove the old glue and reconnect well
  • #14 16396889
    dzejkobs
    As far as I know what to do, thank you all for pointing me to the cause.
✨ The discussion revolves around a Samsung Galaxy S5 experiencing screen illumination issues outdoors, particularly in low temperatures. The user reports that the screen only flashes momentarily when attempting to unlock the device. Despite replacing the battery, the problem persists. Responses suggest potential causes including loose LCD connections, moisture damage, or issues with the flex tape. Several users recommend disassembling the phone to check for secure connections and possible damage, while cautioning against DIY repairs due to the risk of further damage to the display. The consensus leans towards seeking professional repair services for resolution.
