Lenovo Miix 300-10IBY: Unlock More BIOS Options & Enable UEFI CSM for Linux Boot from Memory Card
13920 8
  • #1 16221948
  • #2 16222706
    gradek83
    Help: 930
    Rate: 2104
    Seek help in an English-language forum dealing with this type of modification
    http://www.win-raid.com/forum.php
    Before playing with the bios, make a copy of it and save it preferably on some medium or a cloud.
  • #3 16229221
  • #4 16229264
  • #5 16229280
    gradek83
    Help: 930
    Rate: 2104
    Possibly this maybe it will guide you somehow if you haven't updated it update it BIOS maybe they introduced some new options.
  • #6 16229868
  • #7 19054088
    nici
    Help: 266
    Rate: 979
    Let me dig out the topic, maybe something has changed in the topic?
    Is there any possibility to install linux on this lenovo? Using the W10 on 2GB of RAM with such a slow processor is a tragedy.
  • #8 19054300
    gradek83
    Help: 930
    Rate: 2104
    First, check what guts this tablet is on and then maybe someone has already installed something. Usually the problem is finding drivers for the sound touch panel display etc. Check it won't hurt EXAMPLE Of course, you do everything at your own risk.
  • KDE Neon runs on Miix 300 with isorespin workaround
    #9 19095911
    Porszi17
    I have been using this tablet with the KDE Neon distribution for over a year:
    https://neon.kde.org
    Let's face it, there are no problems ...
    1. Webcams do not work.
    2. There were problems with auto-rotation of the screen, but I coped with my own script.
    3. Touch can travel with the mouse cursor, then it helps to restart the touch. My script resets the touch on a spin, so in case of problems I rotate the tablet and everything works fine again.
    4. Initially there was a problem with detecting connecting headphones via the jack, but after the last update, a few months ago, it works quite well.
    The tablet has a 64-bit processor, but 32-bit uefi, so the system had to be redone with isorespin script: http: //linuxiumcomau.blogspot.com/2017/06/customizing-ubuntu-isos-documentation.html
    I burned the ISO to a USB flash drive using dd on another Linux laptop:
    sudo dd if = / home / user / Downloaded / isorespin_neon.iso of = / dev / sdb bs = 4M status = progress
    If needed, I can drop: my KDE neon iso, the parameters I used for isorespin, my script to handle screen rotation.
The discussion revolves around unlocking additional BIOS options on the Lenovo Miix 300-10IBY to enable UEFI CSM for booting Linux from a memory card. The user expresses frustration with the limited BIOS capabilities, which only allow date and time adjustments. Suggestions include seeking help from specialized forums, disabling secure boot, and updating the BIOS to potentially access new options. Users share experiences with installing Linux distributions, particularly KDE Neon, and highlight challenges such as driver compatibility and hardware functionality issues. The conversation emphasizes the need for proper partitioning and BIOS settings to facilitate Linux installation.
