Booting Lenovo Miix 2 10 from USB for Windows 10 Installation Without Login Password
konrad1213 10443 5
  • #1 16477228
    konrad1213
    Hello, I have a question for all my IT colleagues
    I have a Tablet / Netboot Lenovo Miix 2 10 ", the problem is as follows. I got it from a friend in order to reinstall windows because she did not use it for a long time and forgot the login password, and the second thing is that there is soft 8.1 and she wanted windows 10, but I have a problem running a bootable flash drive, I made a clean windows 10 using Ultra iso, and another one using WinSetupFromUsb and nothing, I installed WinPE on the third one because I found out that it only reads this, but I fell nothing, will someone help me?
    Mainly I mean HOW TO INSTALL A CLEAN WINDOWS WITH USB WITHOUT INTERFERENCE IN THE SYSTEM BECAUSE I DON'T KNOW THE LOGIN PASSWORD.
    P> S> when I started this Miix with power + volume up and clicked boot, it reset, the same when I did the SHIFT + RESTART combination and chose to boot from usb hdd and other options the same, although when I did it with the WinPE connected, the computer started August and CMD popped up, does anyone know what's going on with this?
    Thank you and best regards :) ] Link [/url] [/ code]
  • #2 16477594
    Artur k.
    Help: 1279
    Rate: 1701
    And the pen drive boots correctly on another computer?
  • #3 16477849
    konrad1213
    this is how it boots
  • #4 16477977
    Artur k.
    Help: 1279
    Rate: 1701
    And what version did you put on the pen drive? x86 or x64?
    This device is 32 bit, it will not accept 64 bit.
  • #5 16478263
    konrad1213
    I managed to grasp windows 10 well, but another problem has arisen, it lags really well, the animations are very resistant, etc., do you know how to overcome it now?
  • #6 16478357
    Artur k.
    Help: 1279
    Rate: 1701
    Install All Dedicated Drivers? On MS drivers, this often happens not only in Windows 10.
