Kiano Slimnote 14.2: WiFi Coverage Concerns - Comparing to Aspire 5349, PS3, and TV at Home
Puchaczo 12612 11
Why is the Wi‑Fi on my Kiano Slimnote 14.2 so weak at home, and is there a driver or settings fix for it?
Yes — the most effective fix reported was to change the Wi‑Fi adapter power-management registry value `bLeisurePs` from `2` to `0`, then disable and re-enable the wireless interface in Device Manager; one user said this solved the problem completely and reduced router ping to about 15 ms [#16661694] The adapter in question was identified as a Realtek RTL8723BS, which may be sensitive to power-saving behavior and antenna design [#16605381] You can also try turning off Wi‑Fi card power saving in Windows and, in the router, disable mixed mode, leave 802.11n only, and change to a different channel such as 1/6/11 [#16601804][#16605037] If none of that helps, at least one owner reported no improvement and concluded the device itself was a poor Wi‑Fi performer [#16608626]
  • #1 16601695
    Puchaczo
    From yesterday, I thought I had become a happy owner of Kiano 14.2 but only for a moment. I am coming back home, and here WiFi coverage is a tragedy. The router is max 10m from the laptop, as if it shows two to three lines, but it's a tragedy, sometimes it goes like that, once facebook loads 3 minutes. On the laptop that is next (Aspire 5349) everything goes smoothly without cuts, PS3 and TV also connects seamlessly with the router. I really did not have any requirements for this laptop, only to use the internet, but how to use it like WiFi is barely possible. Does anyone know if this is the case or is something wrong? Maybe some drivers?
  • #2 16601804
    safbot1st
    Help: 2719
    Rate: 1585
    Run the bootable linux and see if anything changes.
    Puchaczo wrote:
    I became a happy owner of Kiano 14.2
    Used? Maybe it's not the fault of the antenna, it's a long load.
    Post a SMART disk from CrystalDiskInfo.
    Turn off power saving in the power options for the wi-fi card.
    I do not know if everything in this KIANO is so "slim", there is no printed PCB on the PCB and that's it. Hence the problems.
    10 meters is often too much for wi-fi, especially as it is wall on the way.
    Enter the router model.
  • Wi-Fi speed drops sharply at 4 m and beyond
    #3 16603989
    Puchaczo
    How do I run this bootable linux?
    Yes, the laptop has a month reportedly turned on 3 times since purchase, I got it not framed, before the format and after the format the internet goes the same.
    After downloading, CrystalDiskInfo does not detect the disk.
    Unfortunately, I did not purge this possibility in Win10
    I just took a test at a distance of not more than 4m from the router (there was no wall along the way). It looks as follows, on the speedtest.net website on an old laptop it shows 45mb of download and 8m of transmission while a few seconds after the end of the test on an old laptop I made on Kiano and shows 7m download and 8mb of upload.
    The second test, somehow 7-8m from the router (wall on the way), the old laptop elegantly overcomes the speednet test 13mb download 6 transmissions and Kiano even does not want to fire the speedtest website (laptops were still around the same distance to the router) . The post I had to write on the old laptop because on the new and electrode does not want to load.
    Router to Orange FunBox 2.0
    I would ask for help because I do not know whether to give / sell this trash or if there are any chances. I do not want to add any external network cards because I already had one in another laptop and did not pass the exam, and the only thing I needed was WiFi, which is a tragedy.
  • #4 16604017
    safbot1st
    Help: 2719
    Rate: 1585
    Download an image of any distribution and prepare a bootable USB flash drive.
    At the startup of the computer, enter the BIOS and select to start from USB.
  • #5 16604817
    polduch
    The program to create a bootable USB flash drive is, for example:
    http://unetbootin.github.io/
    Then download the Linux distribution image, preferably Ubuntu.
    Using the unetbootin program, upload the downloaded image to a USB flash drive and boot according to the advice.
    Linux should present a real picture of the computer's capabilities.
  • #6 16605037
    safbot1st
    Help: 2719
    Rate: 1585
    In the router settings, turn off the mixed environment, leave 802.11n. Change the channel to a completely different one. It can help, although on another laptop and so the range is better than on Kiano ...
  • #7 16605299
    polduch
    Was the computer connected to the net via a cable?
  • #8 16605356
    badboy84
    Help: 1197
    Rate: 1485
    No, because this netbook does not have a LAN card.
    I do not know, but I will say ...
  • Check router mode and 2.4 GHz channel settings
    #9 16605381
    safbot1st
    Help: 2719
    Rate: 1585
    This "flea" (Realtek RTL8723BS) suits you @Puchaczo for WiFi, and where toto has an antenna, I do not know.
    Let @Puchaczo will make recommendations, maybe something will be explained ...
    Added after 7 [minutes]:
    I can not see the antennas:
    Added after 4 [minutes]:
    On top of that, I read that it is a SIDO system, not PCIe, which can also be the proverbial "nail to ...". Suggested solutions:
    https://communities.intel.com/thread/94108
    - channel change on 1/6/11
    - :D using a different card for USB :D
    What a price, such a comfort of work as you can see. :(
    Added after 18 [minutes]:
    Check the author by logging in to the router in which the toto standard connects b / g / n, speed ...
  • #10 16608626
    Puchaczo
    I am again, after a few days of struggle I can afford to comment on this invention. I tested everything you wrote, no improvement. This pseudo laptop does not have any parameters that allow you to do anything but browse the internet, and even this is not good enough!
    I do not know how they sold it, I ate a lot of nerves on it and I will comment on this in the following way - ZENADA. I do not recommend it to anyone, maybe it looks cool but it is completely non-functional, in practice it is only suitable for writing in Word, and I do not write it maliciously. New laptop already purchased, this trash I no longer want to see even on the eyes.
  • #11 16661694
    k4rolek
    I also had the same problem on the same device.
    I managed to find a solution.
    You should:
    The process is short and the key is
    HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Class \ {4D36E972-E325-11CE-BFC1-08002BE10318} \ 000x
    (X may be one of 0/1/2 ...)
    Search for and change the value of bLeisurePs from 2 to 0.
    Then disable and re-enable the wireless interface in Device Manager.
    Link to the source: (I can not insert a link because I have registered to give an answer here) communities intel thread 94108
    It solves the problem completely, until I'm surprised.
    Ping to the router jumped tragically to 1000 even, at the moment max. 15ms.
  • #12 16687992
    Puchaczo
    I tried this method at home but it did not do much, I am already on the new laptop and I do not recommend this trash to anyone - it is not worth wasting money and nerves.
The discussion revolves around WiFi connectivity issues experienced with the Kiano Slimnote 14.2 laptop, particularly in comparison to an Aspire 5349, PS3, and a TV, all of which maintain stable connections. Users suggest various troubleshooting steps, including testing with a bootable Linux USB to assess hardware performance, adjusting router settings (such as disabling mixed mode and changing channels), and modifying power settings for the WiFi card. Despite attempts to resolve the issues, including registry edits and driver checks, the original poster expresses frustration with the laptop's performance, ultimately deeming it unsuitable for basic internet use.
