Connecting 24V Alternator to Voltage Regulator: Wiring Diagram & Cable Routing Guide
Karpikosss1991 11241 3
  • #1 16223804
    Karpikosss1991
    Hello. Could someone help me how to route the cables from this alternator to the voltage regulator? The installation is on 24V. Could anyone have a schematic of how to connect it?
    • Connecting 24V Alternator to Voltage Regulator: Wiring Diagram & Cable Routing Guide WP_20170124_10_54_08_Pro.jpg (1013.05 KB) You must be logged in to download this attachment.
    • Connecting 24V Alternator to Voltage Regulator: Wiring Diagram & Cable Routing Guide WP_20170124_10_50_37_Pro.jpg (2.15 MB) You must be logged in to download this attachment.
  • #2 16224064
    miro.nasz
    Help: 88
    Rate: 171
    Hello!
    There should be another voltage regulator with outputs 67 and 19 for this alternator
    Power supply is connected to 19 after turning the key.
    Contact 67 of the voltage regulator is connected to the alternator brushes.
    to the cube next to the brushes we connect a relay that signals charging.
    If it will not be in the installation of the relay, we connect it with the charging indicator bulb.
    Regulator shown
    D + connect power supply / DF brushes / D- indicator
    Regards Miro. Ours
  • #3 16224352
    Karpikosss1991
    Because the point is that I did a major overhaul of the engine and did not take a picture of how the cables were connected. Now I installed the engine and I don't know how to connect it, and I had such an alternator and regulator all the time.
  • #4 16224455
    miro.nasz
    Help: 88
    Rate: 171
    Hello!
    In the alternator, the M6 threaded stud / pin is insulated at the ankle, connect - battery cable / thick /
    Alternator brushes / thin cable / for DF controller in the controller.
    In the D + controller to the ignition switch. The current is to be turned by turning the ignition switch.
    D-regulator to the indicator light in the board.
    If you have an ammeter in your vehicle, it is connected in series with the power supply and you do not move it.
    Miro.Nasz
