Ursus-c330 Alternator Installation: Dashed Line from Rectifier to Pin 30 Query
borgg 104673 5
  • #1 15273212
    borgg
    Rate: 31
    A short question regarding the diagram below. Why does "+" from the rectifier go to pin 30 (power) as a dashed line? Does it matter if it is a dotted line?
  • #2 15273301
    bearq
    Help: 414
    Rate: 1602
    It doesn't matter, there were different connection configuration.
  • #3 15273771
    borgg
    Rate: 31
    So this dashed line is some connection variant? Because some reason had to be that it was drawn as dashed. What should I apply? Assemble the installations as it is in the diagram, only treating the dashed line as an ordinary continuous line, or if I choose the dashed line option, do I have to modify something else in the diagram? I would like to understand that.
    mikdar
    Rate: 9
    You have the original wiring diagram. The thickness of the line tells you what to use the cross-section of the electric wire. The dashed line is 2.5mm if I remember correctly. I would have to check it out.
    bearq
    Help: 414
    Rate: 1602
    Read from here where you got the diagram, what the author meant, most often these are different connection variants, pin 30 is the main contact supplying the ignition switch, so you can also connect this contact directly to the battery and it will be fine too. Most often, the voltage is taken from the starter terminal, as in your diagram
  • #6 15274818
    borgg
    Rate: 31
    Ok, thanks gentlemen. In the diagram, the dashed symbol means a cross-section of 6mm2, and he will use something like that. Thanks for the help. You can close it, unless someone wants to add something else.
