Upgrading to Firefox 50 on Windows XP Home 2002 SP2 - Compatible Versions & Service Pack 3
ytrix 3549 10
Can Firefox 50 be installed on Windows XP Home SP2, and do I need Service Pack 3 for it to work?
Yes—install Service Pack 3 anyway, because it should already be on the system, but Firefox 51’s requirements still list Windows XP SP2, so the browser should work on your machine after updating [#16226822][#16226986] If the computer is connected to the network, the installed Firefox will then update itself [#16226914]
  • #1 16226814
    ytrix
    I was using the old Firefox browser (17 I think), I had to format the disk. My hardware is Windows xp home 2002 SP2.
    I don't know and I'm not sure about other browsers like this one. I tried to upload Firefox 50, but something always popped up, that something was missing or an error, etc., and even restarted. I wanted to ask. Can i upload it? http: // ww w. dobreprogramy. en / Windows-XP-Service-Pack-3, Program, Windows, 12243. html (remove spaces - I can't add links) so that my hardware works in SP3. Then I will have no problems with uploading this 50? Maybe there is another version of MF that should fit my program.
    leonov
    Help: 1039
    Rate: 2247
    Service-Pack-3 should be installed a long time ago, so you have disabled updates, it is not wise.
    The system requirements for FF are:
    Firefox 51.0 System Requirements
    Windows
    Operating Systems (32-bit and 64-bit)
    Windows XP SP2
    Windows Server 2003 SP1
    Windows Vista
    Windows 7
    Windows 8
    Windows 10
    It follows that after the update, version 51 will work.
  • #4 16226921
    ytrix
    Ok. I had the updates turned on because I noticed MF 46 and problems with using the net. I did a disk formatting today, so I want to make sure I upload it to SP3? !!!
    mariuszp19
    Help: 310
    Rate: 409
    ytrix wrote:
    so I want to make sure to upload it to SP3? !!!
    Necessarily.
  • #6 16227380
    ytrix
    Thanks, I'm on my way :D
  • XP SP3 upgrade fails to resolve recurring system crashes
    #7 16237333
    ytrix
    I played SP3 with the thought that the problems would end. Unfortunately, I still can't get into the net. Despite scanning with Avast or Panda - no viruses.
    The computer restarts by itself, information pops up:
    - Mozilla crash reporting tool. Firefox crashed due to an error. Next time you start it, it will try to restore your open windows and tabs .... (and over and over)
    - Generic Host Process for Win32 Services has encountered a problem and will close ...
    - Explorer exe has encountered a problem and will close ....
    - Microsoft Windows. The system has recovered from a serious error .....
    Over and over again.
    Is it possible that the old man "kicked the calendar"?
  • #8 16237974
    Kasek21
    Help: 4981
    Rate: 3547
    Download here: http://www.memtest.org/#downiso
    Unpack, burn the image to disc and boot the computer from it. You can also download the version on a USB stick. (two program passes).
  • #9 16239299
    ytrix
    Thanks, but I don't know anything about it. I'm pissed off and I'm buying a new computer
  • #10 16239350
    Kasek21
    Help: 4981
    Rate: 3547
    As you think - if all this close the topic.
  • #11 16239497
The discussion revolves around upgrading to Firefox 50 on a Windows XP Home 2002 SP2 system. The user faced installation issues and sought advice on whether upgrading to Service Pack 3 (SP3) would resolve these problems. Responses indicated that Firefox 51.0 is compatible with Windows XP SP2 and that updating to SP3 is necessary for better functionality. The user later reported persistent issues, including system crashes and error messages, leading to considerations of purchasing a new computer. Suggestions included using Ubuntu Live as a troubleshooting method, but the consensus was that a hardware upgrade might be inevitable.
