Upgrade Windows XP to a Newer Version (Windows 7, 8, 10) on Older Computers - Legal & Free
pechowiec11111 9723 9
Can I legally upgrade an old Windows XP computer to Windows 7, 8, or 10 for free?
No, there is no free, legal way to upgrade Windows XP directly to a newer Windows version; if you want Windows 7, 8, or 10, you will usually need a new license and possibly a different computer [#16534510][#16534604] Windows XP itself does not stop working just because support ended, so the old PC can continue to run [#16534604][#16534619] To find out whether the hardware can handle a newer system, check the exact PC configuration and compare it with Microsoft’s compatibility/system-check tools [#16534505][#16534538]
  • #1 16534482
    pechowiec11111
    Rate: 9
    Hey
    My mother has Windows XP. Apparently, it will stop working from July. Is there any way to free it and legally update it to a higher version? Such that the computer can handle because it is quite old. I will be grateful for the advice
  • #2 16534505
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Go to the Microsoft website and scan your computer for possible system change.
  • #4 16534510
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    No.
  • #5 16534523
    byku022
    Help: 6
    Rate: 20
    Xp for several years is probably not supported, the methodology of action: Change the computer and Windows, and by the way is the opinion that recent updates spoil computers :(
  • #6 16534538
    kokapetyl
    Help: 1787
    Rate: 2101
    At this point, it would be good to show off what kind of equipment it is (its configuration). Without this basic information, we do not know what he "will bear"
  • #7 16534604
    Artur k.
    Help: 1279
    Rate: 1701
    You told some good stupidity. Operating systems do not stop working themselves. I still have a computer with Windows 95 and ... surprisingly works.
    If your mother needs a computer, leave it as it is, and if you want to change it, you will probably need to replace the whole computer. Today, a single-core processor, although it would still be suitable for most things, even browsing the Internet (especially multimedia on the Internet) becomes quite cumbersome.
  • #8 16534619
    Dra98
    Help: 1321
    Rate: 1076
    Windows 98 or NT 4.0 systems still work, so Windows XP will not stop working.
    Leave equipment as it is and use it works and is sufficient.
    Edit: I have already been warned.
  • #10 16539291
    pechowiec11111
    Rate: 9
    cool
    Thank you all for the hints. They came in handy, the computer works
The discussion revolves around upgrading Windows XP on older computers, particularly in light of its impending end of support. Users suggest checking the Microsoft website for compatibility and updates, while some argue that Windows XP will continue to function despite the lack of official support. There are concerns about the performance of newer operating systems on older hardware, with recommendations to consider the computer's specifications before attempting an upgrade. Some users mention that Windows XP received a security update in 2017, indicating that it may still be viable for use. Overall, the consensus leans towards either maintaining the current system or considering a complete hardware upgrade if a newer OS is desired.
