Payer 10 - Export of a single client from the SQL database to an MDB file
tzok 16248 4
  • #1 16230279
    tzok
    Help: 3174
    Rate: 6529
    Long time ago, I did something like this and succeeded, and this time I can not deal with this problem. Is Płatnik 10, which operates on the basis of SQL 2012 Express. I need to export data from one client to an MDB file (Access). I progress w / g THIS guide. I assume a new SQL database, I export the data of the selected client (payer) to it, and on the basis of MASTER performs the query:
    sp_configure 'show advanced options', 1;
    RECONFIGURE;
    GO
    sp_configure 'Ad Hoc Distributed Queries', 1;
    RECONFIGURE;
    GO
    I switch to this database and try to convert it to MDB, which unfortunately ends with various errors.
    Or I have a mistake:
    Cannot create instance of OLE DB provider "MSDASC" for linked server "(null)"
    ... or when I move the SQL database to another server:
    OLE DB provider "Microsoft.Jet.OLEDB.4.0" for linked server "(null)" returned message "Nie można znaleźć pliku ''."
    If I try to give full permissions for Everyone to the directory in which I want to create an MDB file, I get a similar error, only with the tip "Disk or network error". If I install Payer on the same computer as SQL Server, the tip is "Unspecified error".
    I tried on Windows 7 x86 and x64 and respectively on the 32 and 64 bit version of SQL Server 2012.
  • #2 16230361
    dzielik
    Help: 20
    Rate: 34
    maybe this:
    http://sqlish.com/msg-7302-level-16-state-1-l...-ole-db-provider-%E2%80%9Cmicrosoft-ace-oledb -12-0% E2% 80% 9D-for-linked-server-% E2 9Cnull% 80%%% 80% E2 9D /
    or this:
    https://www.codeproject.com/Questions/747570/...t-create-an-instance-of-OLE-DB-provider-MSDAS
    possibly :)
    https://www.codykonior.com/2014/05/02/msdainitialize-minimum-required-permissions/
    pogoogluj because the results a lot, and as you can see and different solutions are the problem.
  • #3 16230866
    Dra98
    Help: 1321
    Rate: 1074
    It seems to me that by default in Microsoft SQL Server there is no database creation function enabled from program levels - https://msdn.microsoft.com/en-us/library/ms187569(v=sql.110).aspx
    I think Microsoft SQL Server 2005 worked OK.
  • #4 16230884
    tzok
    Help: 3174
    Rate: 6529
    :arrow: work: Googlował and a lot, but so far it did not bring results.
    :arrow: Dra98: The problem is with the creation of the Access database, not SQL. Even better - an empty database is created, an error occurs when you try to import data into it.
  • #5 16244068
    tzok
    Help: 3174
    Rate: 6529
    I do not know what the credit goes to the end (Windows XP or SQL Server 2005) but I installed the payer on the Windows XP virtual machine with SQL Server 2005, to which I moved the database from SQL Server 2008 through the SQL script, and thus I was able to migrate the SQL database to Access from the Payer level.
