Amica 601CE3.332TaYW Electric Stove: How to Replace the Oven Thermostat and Remove Ceramic Hob
jareckim 13281 6
  • Request for ceramic hob removal instructions and thermostat replacement
    #1 16231530
    jareckim
    Help: 5
    Rate: 49
    I need to replace the oven thermostat in the Amica 601CE3 series electric stove. with ceramic hob. I can't find a disc removal instruction anywhere. There are instructions, but gas-electric cookers, and electric cookers nobody posted anywhere. Probably the plate is screwed somehow to the kitchen housing, but I do not know where, and I would not want to damage anything. The kitchen is with friends and I have not had the opportunity to watch it anymore because I do not have a thermostat yet. Can anyone suggest how to take it apart?
  • #2 16232848
  • #3 16232948
    jareckim
    Help: 5
    Rate: 49
    But you need to remove the hob and I'm not asking with what but how. And where should I use this screwdriver and I don't ask how, but where. Where are the screws? But seriously, not pouring water on points. Have you ever seen such an Amica cooker up close?
  • #4 16233034
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    There's no need to.
    After opening the oven, from the bottom of the grill with knobs.
  • #5 16233240
    jareckim
    Help: 5
    Rate: 49
    So just unscrew one screw, remove the knobs, remove the cover and you will have access to the thermostat. You probably also have to unscrew the cover at the back. But it simplifies the whole operation very much. I was afraid that you would have to fight the record. Thank you, very helpful tip.
  • #6 16234702
  • #7 16235011
    jareckim
    Help: 5
    Rate: 49
    skryn wrote:
    But not necessarily, because it is better to disassemble the ceramic plate itself (two screws on the back and movement backwards with the entire plate for disassembly), it is easier this way.
    This is what I meant and is in the subject. Because the need to use a Phillips screwdriver is so obvious that it is a pity to write about it and hence my question, whether you saw such a stove, but with this answer you have proved that it is. Thank you, I'm closing the topic.
The discussion revolves around replacing the oven thermostat in the Amica 601CE3.332TaYW electric stove with a ceramic hob. Users share insights on how to access the thermostat, emphasizing the need to remove the ceramic hob. The process involves unscrewing a single screw, removing the knobs, and taking off the cover to access the thermostat. Some users suggest that disassembling the ceramic plate itself may be easier, as it allows access to the upper screws without needing to remove the entire hob. A Phillips screwdriver is the only tool required for the operation, which is described as straightforward and manageable within ten minutes.
