Opel Corsa C 1.0 Petrol: Encoding Used Engine Driver with MaxiECU Interface & PIN
adax2 10512 8
  • #1 16485715
    adax2
    Rate: 32
    Hello. I have such a question. I need to replace the driver in Opel Corsa 1.0 petrol. I have a pin from this car. I have a maxiecu interface with an Opel license. If I buy a drug, will I program it for the car, do I have to meet any conditions ...?
  • #2 16485797
    sk700
    Help: 173
    Rate: 420
    You must buy a driver logged out or know the donor pin. I did not have contact with this maxiecu but elm does not bode well so I do not know if you will be able to add the driver to the car with it. You can also buy a driver without a pin (it will be cheaper) and go to someone who has the equipment to log out without a pin.
  • #3 16485860
    adax2
    Rate: 32
    I know what is elm. I don't have elm but maxiecu mpm. It's an interface for full diagnostics. Before I read the pin.
    How do you log out?
    And is programming done from the position of the engine driver or immo, because I have no programming option in the engine, and there is reset, matching, and a few more in immo, I can't remember anymore?
  • #4 16485888
    sk700
    Help: 173
    Rate: 420
    As I wrote, I have not had contact with this software. Look for functions in immo. You should be able to program the immo function there and then exchange the ecu.
  • #5 16485942
    piotrekwoj1
    Help: 947
    Rate: 3433
    Logging out is nothing but ECU reset and during this operation you enter the pin you read from the new ECU. Later in immo you have something like programming the immo function in CIM and ECU, you choose ECU and that's how much you program VIN.
  • #6 16485991
  • #7 16486661
    piotrekwoj1
    Help: 947
    Rate: 3433
    Bieda z nędzą wrote:
    piotrekwoj1 wrote:
    At CIM.
    CIM in Corsa C?
    The fact I hurried up.
  • #8 16487024
  • #9 16487062
    tomasz0703
    Help: 69
    Rate: 489
    You will do it with one of 3 tech2 devices, op-com, opelscaner.
The discussion revolves around replacing the engine driver in an Opel Corsa C 1.0 petrol vehicle using a MaxiECU interface. The user inquires about the conditions for programming a new driver with a known PIN. Responses indicate that the driver must be logged out or a donor PIN is required. The MaxiECU interface is mentioned as a diagnostic tool, but there are concerns about its compatibility for programming. Logging out involves resetting the ECU and entering the PIN from the new ECU, followed by programming the immobilizer (immo) function to match the new ECU. Suggested tools for this process include Tech2 devices, Op-Com, and OpelScanner.
