Laguna II Card Programming: Equipment Recommendations for Key Card Coding
pawel1fv 10116 15
What equipment do I need to program a Renault Laguna II key card?
A cheap FNR or a regular VAG KKL cable is enough for Laguna II card programming, and a Multidiag/Autocom/Delphi-type interface will not do it [#16232281] [#16639906] [#16638336] If you only need to program one card, it may be easier to go to someone who already has the right equipment [#16233601] One reply also notes that the card must be clean, not taken from another car [#16237758]
  • #1 16232279
    pawel1fv
    Hello, what equipment should I buy to program the Laguna II card?
  • #2 16232281
    robi1214
    Help: 151
    Rate: 869
    Cheapest FNR.
  • #3 16233601
    SanchosX
    Rate: 75
    Dude, if one is better to drive to someone with equipment. And if for a profit fnr I advise against carproga better, preferably in org
  • #4 16237690
    pawel1fv
    and the card must be clean or can it be from another car?
  • #5 16237758
    szymitsu21
    Help: 343
    Rate: 1300
    only clean.
  • #6 16637806
    Michel424
    Rate: 13
    I'll step under the topic. I have multidiag for several days and I would like to program the card with it, can anyone know how to do it?
  • #7 16638336
    sebap
    Help: 538
    Rate: 1082
    Nobody knows how, because you won't do it with this equipment.
  • #8 16639079
    Michel424
    Rate: 13
    If ddt is overwhelming then it should be all the more so I think.
  • #9 16639200
    sebap
    Help: 538
    Rate: 1082
    It's alive downloaded from Autocom and Delphi and that equipment didn't do it but what harms you to look for this option?
  • #10 16639501
    Michel424
    Rate: 13
    That's exactly the same
  • #11 16639762
    genek1000
    Help: 289
    Rate: 1057
    Do not compare DDT 2000 is just top ... Chinese.
    DDT 2000 is a program on which factories work during production, hardly anyone has any idea about it.
  • #12 16639786
    milejow
    Help: 1563
    Rate: 5149
    Holy words, it has programming / configuration options that CLIP doesn't even dream of. For example - adjusting the duration of the direction blink and the distance between individual flashes, as a result you can insert the LED bulbs while maintaining their proper operation.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #13 16639875
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    Provided that what was called DDT2000 is the original, not a Chinese copy.
  • #14 16639893
    genek1000
    Help: 289
    Rate: 1057
    If I'm not mistaken, all DDT2000 versions circulating on the network are the originals.
    And the interface you have is what you have.
  • #15 16639906
    sebap
    Help: 538
    Rate: 1082
    Regular VAG KKL for a dozen zlotys and nothing else is needed but it seems that the topic has gone wrong.
  • #16 16639956
    Michel424
    Rate: 13
    I have this cable but it pissed me off that I couldn't configure it properly and I didn't like the topic. For over a year I have embraced the subject and not only me. This interface has started immediately and is easy to use.
The discussion centers around the equipment needed for programming the Laguna II key card. Recommendations include using FNR equipment, with a caution against using Carprog for profit-oriented tasks. It is emphasized that the card must be clean and not sourced from another vehicle. Users express that common diagnostic tools like Multidiag are inadequate for this task, while DDT2000 is highlighted as a superior option for programming and configuration, surpassing other tools like CLIP. The importance of using original DDT2000 software is noted, as counterfeit versions may not function properly. A VAG KKL interface is also mentioned as a low-cost alternative, though some users report difficulties in configuration.
