Fiat Stilo 2003 Key Coding Cable & Program: Recommendations for Buying & Usage Options
tomo_git 12555 11
Which cable and program can I use to program a key for a 2003 Fiat Stilo with a code card?
Use an ELM327 OBD2 interface with MultiECUScan (or FiatECUScan); one user reported programming a Fiat Stilo key this way [#17032371] It may need a simple modification to communicate with all Stilo systems: remove the resistor between pins 6 and 14 if the interface measures about 120 Ω there [#17032406][#17034767] The interface can be USB, Bluetooth, or Wi‑Fi, and USB/Bluetooth were reported working [#17032445] Be careful whether you mean the remote or the immobilizer/transponder: the remote is simpler, but transponder programming may require a Megamos Crypto 48 precoded chip, and a brand-new blank transponder may not program with MultiECUScan [#17032595][#17036434][#17036845]
  • #1 17032350
    tomo_git
    Rate: 11
    I am looking for a cable and program that will help program a key for Fiat Stilo 2003. I have a code card :)
    Which cable to buy and the program I can use to do it?
    mattm
    Help: 28
    Rate: 33
    At STILO, I used the cable to program the key:
    CABLE INTERFACE ELM 327 (from thunder on the well-known auction site)
    '' Multi ECU Scan '' or 'Fiat ECU Scan' program
  • #3 17032381
    tomo_git
    Rate: 11
    OKAY.
    So the ELM 327 ODB 2 cable will whisk?
  • #4 17032406
    mattm
    Help: 28
    Rate: 33
    tomo_git wrote:
    OKAY.
    Yes. It will work. You may need a modification of it to communicate with all systems in STILO (I don't really remember now if Body Computer requires it). But the modification consists only in the removal of one resistor. A beginner electronics can handle this easily.
    Under this link is a description of the conversion
    And here the whole thread of the Fiat Klub forum is not long and there is useful information
  • #5 17032415
    tomo_git
    Rate: 11
    Ok ok This is an abscess.
    I found such a cable for wifi (do you take traditional)?
  • #6 17032445
    mattm
    Help: 28
    Rate: 33
    I have a cable for USB and BLUETOOTH. Both work. I haven't tried Wi-Fi yet, but it probably will work too. I also have an abscess. :)
  • #7 17032595
    ste
    Help: 184
    Rate: 278
    Do you want to program a remote control or transponder (to disarm the immo)?
    I am asking because when it comes to programming a brand new transponder I am afraid that you will not do it with Multiecuscan. Of course, there is such a function as key programming, but (if I'm not mistaken) to do this you must have a Megamos Crypto 48 transponder precoded for your car. Bought a new "clean" is unlikely to be programmed.
  • #8 17032623
    mattm
    Help: 28
    Rate: 33
    tomo_git wrote:
    I am looking for a cable and a program that will help program the key to Fiat Stilo 2003 I have a code card
    The author of the post wrote that he wants to program the key (I understood that simply the remote control to open the door does not work).
    I did it using the interface and program I mentioned.
    Honestly..? I didn't even know that it had to be done somehow differently.
  • #9 17034618
    tomo_git
    Rate: 11
    I looked and read the topic with the modification. I bought ELM327 wifi and I can't find these resistors.
    I upload photos here
    https://imgur.com/gallery/HvbcM " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://imgur.com/gallery/HvbcM
    • IMG_1193.JPG (637.31 KB) You must be logged in to download this attachment.
    • IMG_1194.JPG (611.49 KB) You must be logged in to download this attachment.
    • IMG_1195.JPG (532.21 KB) You must be logged in to download this attachment.
  • #10 17034767
    mattm
    Help: 28
    Rate: 33
    But wait...
    Have you checked that it is not communicating with BCM?
    In the MultiEcuScan program (as in the picture below) there are DTC Scan and Scan buttons.
    What systems does the program detect in the car after using these buttons without modifying the interface? Because it may turn out that you do not need to modify the interface.
    And you didn't answer your friend's question: Is it about programming the remote control to open the door or the immobilizer itself? Because I didn't ask about it before.
    // Edit
    Under this link more information about Fiat conversions. Maybe you'll find your interface there. The thing is about the resistor between legs 6 and 14. It is simply not in the interface. If you measure the resistance between these pins with the meter and if the meter indicates 120 ohm, then you need to locate and remove this resistor (do not connect anything in return).
  • #11 17036434
    tomo_git
    Rate: 11
    It's about the pilot and immo
  • #12 17036845
    mattm
    Help: 28
    Rate: 33
    The remote control to open the door is like that. But an immobilizer can be a problem.
    Here there is a thread about it.
The discussion centers around programming a key for a 2003 Fiat Stilo using a suitable cable and software. Recommendations include the ELM 327 cable, specifically the OBD2 version, which can be sourced from auction sites. Users suggest using the "Multi ECU Scan" or "Fiat ECU Scan" programs for key programming. Some users mention the need for a modification to the ELM 327 cable to ensure full communication with the vehicle's systems, particularly the Body Computer. There is a distinction made between programming a remote control and a transponder key, with concerns raised about the ability to program a new transponder without a pre-coded Megamos Crypto 48 transponder. Users also discuss various cable types, including USB, Bluetooth, and Wi-Fi, noting that while USB and Bluetooth have been tested successfully, Wi-Fi remains untested.
TL;DR: For 2003 Fiat Stilo key work, ELM327 + MultiECUScan works; some clones need removing 1 resistor. "Yes. It will work." [Elektroda, mattm, post #17032406]
Why it matters: This helps DIY Stilo owners pick the right interface, avoid BCM comm issues, and know immobilizer limits.
Which cable and software do I need to program a 2003 Fiat Stilo key?
Use an ELM327 OBD‑II interface with MultiECUScan (MES) or FiatECUScan. Users report programming Stilo keys with this combo. Start with a decent ELM327, then pair it to MES on a laptop for access to key routines. [Elektroda, mattm, post #17032371]
Does an ELM327 OBD2 cable actually work for Stilo key programming?
Yes. “It will work.” Some Stilo modules can need a minor interface mod, but ELM327 with MES handles key programming. If BCM access fails, check the resistor guidance below before retrying the procedure. [Elektroda, mattm, post #17032406]
Do I need to modify my ELM327 to access the Body Computer (BCM)?
Check your unit. Some clones have a 120 Ω link between pins 6 and 14. If you measure 120 Ω across those pins, remove that resistor to restore CAN communication with the BCM. Confirm with scans before any hardware change. [Elektroda, mattm, post #17034767]
How can I test if my interface sees the BCM before modifying it?
Open MultiECUScan. Use DTC Scan and Scan to list detected systems. If the BCM appears, you can proceed without hardware changes. If not, measure between pins 6 and 14; a 120 Ω reading points to the removable link. [Elektroda, mattm, post #17034767]
Which ELM327 version should I buy: USB, Bluetooth, or Wi‑Fi?
USB and Bluetooth versions were confirmed working by a user who tried both. The same user did not test Wi‑Fi. For a proven path, choose USB or Bluetooth for your Stilo key work. [Elektroda, mattm, post #17032445]
Can MultiECUScan program the remote locking on a Stilo?
Yes. A user restored a non‑working remote using an ELM327 and the mentioned software. Connect to the BCM in MES and run the key programming routine to pair the remote. [Elektroda, mattm, post #17032623]
Can MultiECUScan code a brand‑new immobilizer transponder?
Not with a clean chip. MES lists a key programming function, but the transponder must be a Megamos Crypto 48 pre‑coded for your car. Blank chips are unlikely to program successfully. [Elektroda, ste, post #17032595]
What transponder chip type does the 2003 Stilo use?
Megamos Crypto 48. Ensure the transponder is pre‑coded for your specific Stilo before attempting immobilizer programming in MES, or the process can fail. [Elektroda, ste, post #17032595]
Step‑by‑step: How do I prep my ELM327 for BCM access?
  1. In MES, run DTC Scan/Scan to see which systems are detected.
  2. If BCM is missing, measure resistance between OBD pins 6 and 14.
  3. If you read 120 Ω, locate and remove the internal resistor, then rescan. [Elektroda, mattm, post #17034767]
What if the remote works but immobilizer coding fails?
Treat them as separate tasks. Remote pairing is achievable with ELM327 and MES. Immobilizer coding fails without a pre‑coded Megamos 48 chip. “The remote control to open the door is like that. But an immobilizer can be a problem.” [Elektroda, mattm, post #17036845]
Does FiatECUScan work, or do I need the newer MultiECUScan?
Both names are used for Stilo key work. Pair your ELM327 with MultiECUScan (current name) or the older FiatECUScan to access key procedures. [Elektroda, mattm, post #17032371]
How do I start key programming in MES once BCM access works?
Connect to the Stilo’s BCM in MES, then open the Key Programming procedure and follow the on‑screen prompts. This function is present in the software’s adjustment routines. [Elektroda, ste, post #17032595]
Where can I read more about the ELM327 CAN modification?
See the conversion guides linked in the thread that show the 120 Ω removal and discuss BCM communication. They’re shared as references for Fiat interfaces. [Elektroda, mattm, post #17032406]
