[Solved] Adding a New Opel Vivaro 2.0 CDTI 90 (2008) Key: OPCOM Connection & Interface Recommendations
balcer97 14184 19
How can I program a new key for a 2008 Opel Vivaro 2.0 CDTI and delete the lost key, since OPCOM will not connect for this procedure?
OPCOM is not the right tool for this job, and during key programming you should not connect to the engine controller; Vivaro is treated as a hybrid/renault-based system, so users suggested using a different interface such as Tech2, CarProg, IMMO TOOL or FVDI instead [#16602370][#16604156][#16604744] One user confirmed that a CarProg clone from China worked on a 2008 Vivaro, even though the manufacturer listed it only up to 2006, by going into the IMMO tab and selecting Renault Traffic [#16608275] In that procedure, the device reads the immobilizer, then you choose Add key/card, and it warns that all keys/cards will be erased before continuing [#16608275] The important point is that the procedure erases all stored keys and then you must program all keys you want to keep, old and new, in one session [#16608453][#16608849] Another reply added that you enter the number of keys you want to program and follow the ignition on/off prompts [#16608445]
  • #1 16602350
    balcer97
    Rate: 17
    Hello forum users, I have a question regarding the coding of a new Opel 2.0cdti key 90 cdti from 2008. I have an opcom, but unfortunately I can't connect it, because, unfortunately, already with Renault, how could someone recommend a relatively expensive interface to program the key , because they prefer PLN 300 for the key clone, I would prefer to add and buy the interface and add it to the ecu and delete the lost second key. Thank you for your reply and best regards.
  • #2 16602370
  • #3 16602720
    balcer97
    Rate: 17
    Unfortunately, but no such option in the program as the body / immobilizer, it is no longer Opel only Renault unfortunately, I found such an interface as a Renault Clip only if someone could confirm with this interface I can definitely add a key because it is a shame to throw money on a device which I will diagnose I only have mistakes.
  • #4 16602998
  • #5 16603213
    balcer97
    Rate: 17
    This instruction does not apply to vivaro. There is no immobilizer option on this model for this model.
  • #6 16604156
    jokerro
    Help: 207
    Rate: 1142
    Vivaro is a crossbreed, and more like a nun, I can't say anything to myself, I can but maybe tech2 but I never checked, I always write these hybrids in a file because I'm sure he'll go in 1 shot.
    I can add you to the file.
  • #7 16604245
    balcer97
    Rate: 17
    How can you explain to what file? and what to do with it? that would be grateful, besides, I would order a renault clip but nowhere can I find the info if I will do it.
  • #8 16604744
    mako110
    Help: 37
    Rate: 264
    It goes from a shot on the cable IMMO TOOL, CARPROG, FVDI, but these toys are not cheap ...
  • #9 16604820
    balcer97
    Rate: 17
    Ok thanks for the information, I will try carprog because I have it.
  • #10 16606704
    kamiloskop
    Help: 42
    Rate: 278
    How is the issue of adding a key to the 1.9 dci from 2003?
  • #11 16606831
    adrian1201
    Help: 128
    Rate: 413
    Same as in Vivaro.
  • #12 16607300
    kamiloskop
    Help: 42
    Rate: 278
    So I come with a clean key, i.e. a new one, plus a new transponder and driving a new version of CP can handle it ??
  • #13 16607412
    mako110
    Help: 37
    Rate: 264
    That's right, but I don't know if the cp clone will be overwhelming ... :?: :?:
  • #14 16608275
    balcer97
    Rate: 17
    buddy mako110 you were right to connect with carprog, mine is from china and connected to vivro 2008 although I read on the producer's website only until 2006. and here is a surprise :) I read newer, I just want to find out because I went to the immo tab, I chose renault traffic connected, I gave read immo, I read the keys were added 4 but strangely duplicated, I switched to key 5 and gave Add key / card and the message all keys / cards popped out will be erased and asks whether to continue as I give it will not clear me the keys that already exist ??
  • #15 16608287
    adam7009
    Help: 656
    Rate: 1631
    ......... cleared, only those you entered during the procedure were left.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #16 16608418
    balcer97
    Rate: 17
    that is, according to this, there can only be one key because each time it will delete the existing one, something rather wrong here? unless for one procedure you can add existing and new ??
  • #17 16608445
    adam7009
    Help: 656
    Rate: 1631
    why?
    during the procedure, enter the number of keys you want to program and add them, you have the message when to insert or remove from the ignition, or turn the ignition on or off.
  • #18 16608453
    robi1214
    Help: 151
    Rate: 868
    During the procedure, it erases all saved keys, then you program the ones you have.
  • #19 16608849
    mako110
    Help: 37
    Rate: 264
    Just as colleagues write, delete all and add the old ones from this car and the new one (clean, transcoded under a given make and model).
  • #20 17323534
    balcer97
    Rate: 17
    I wrote thank you for the info and best regards :)
✨ The discussion revolves around the challenges of programming a new key for a 2008 Opel Vivaro 2.0 CDTI using an OPCOM interface. Users share their experiences with various diagnostic tools and interfaces, noting that the OPCOM may not connect properly for key programming. Recommendations include using the Renault Clip interface, IMMO TOOL, CARPROG, and FVDI for successful key addition and ECU interaction. It is highlighted that during the key programming process, existing keys may be erased, necessitating the reprogramming of all keys. Users express concerns about the cost of cloning keys and seek confirmation on the effectiveness of the suggested tools.
