[Solved] Fiat Ducato 2013 - Key Programming with Remote: Pin Code or Precoded Key Needed?
adamski123 14871 6
  • #1 17472524
    adamski123
    Help: 46
    Rate: 250
    Hello colleagues, I have a question whether to program the key with the remote control for Fiat Ducato just a pin code or the key must be precoded
    best regards
    ml3ko_RS
    Rather recoded.
    adam7009
    Help: 656
    Rate: 1635
    definitely precoded.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
    Sivyx
    Help: 19
    Rate: 64
    Less than $ 20 and you are precoded from majfrends from Ali. Just cut and program. If you buy a key for this car, 99% will be already precoded, unless you use it
    look for the precoded PCF7946 on this model and resolder. But if you can new from Ali for 20 $ ...
  • #5 17473326
    adamski123
    Help: 46
    Rate: 250
    Hello, that is all you need is a PIN and a key
    Sivyx
    Help: 19
    Rate: 64
    And where do you order the key from? send me the link. On pw you have with alli for $ 20. How you care about time and cheapness :) on alledro there is an offer for 30 PLN with a precoded PCF, you are looking for a key to use, flip a chip and program in 70 PLN, you can fit :)
    Just don't buy those for PLN 280 with alledro, because these are quinces (they work well), but you can have them for $ 20 instead of PLN 280.
  • #7 17474829
    adamski123
    Help: 46
    Rate: 250
    Hello topic closed. Thank you very much.
The discussion centers around programming a key with a remote for the Fiat Ducato 2013. Participants confirm that a precoded key is necessary for successful programming, rather than just a PIN code. It is noted that precoded keys can be sourced inexpensively, with suggestions to purchase from online platforms like AliExpress for around $20. Users emphasize the importance of ensuring the key is precoded, specifically mentioning the PCF7946 chip, and caution against overpriced options. The conversation concludes with the author expressing gratitude for the information provided.
