[Solved] Step-by-step Guide to Coding a New Key for Renault Laguna 2 without Old Card
lukas198107 10689 7
  • #1 16647320
    lukas198107
    Rate: 45
    Dear professionals. I have a huge problem with my car. Mianowice lost one card and the other was lost. The worst of it all
    that I live in Norway and I would have to pay for obtaining a key as for grain. I bought a blank card and want to encode it. Could someone write step by step how to go about it ?? !! I know I need to get a key pin. I have no idea where to look. What program is the best to embrace it? I have access to a computer with which I can connect only what next ?? Many thanks in advance for constructive help.
  • #2 16647333
    andrzej20001
    Help: 1578
    Rate: 6669
    Constructively, buy a new card and encode it. Earnings are pretty good there. You can't do anything.
    Moderated By CameR:
    Reg. 3.1.11. Do not send messages that add nothing to the discussion. They do not solve the user's problem.
  • #3 16647345
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    CARPROG can add a card without knowing the PIN and without the need for a working card.
    Otherwise CLIP needed.
  • #4 16647656
    damdam
    Help: 274
    Rate: 950
    constructively, you need to resurrect the dead one - e.g. by mail order, and then when you come to PL to code this new one ;)
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #5 16648005
    kamiloskop
    Help: 42
    Rate: 279
    Buddy, you tried this option and it works. Used card e.g. with precoded transponder plus carprog and driving? What version did you do that? Original or rice?
  • #6 16658227
    lukas198107
    Rate: 45
    I was able to fix the card at the electronics. Such curiosity :) The price of a key in Norway for my car is around 2500 PLN. Thank you for the answers and best regards.
  • #7 16659627
  • #8 17684738
    lukas198107
    Rate: 45
    The problem was at the contacts. The professional sold out all the connections and the card flashed. Reniaja has already been replaced with a newer car :) .
The discussion revolves around the challenge of coding a new key for a Renault Laguna 2 after losing both existing keys. The user seeks a step-by-step guide to encode a blank card, mentioning the need for a key PIN and suitable software. Responses suggest using CARPROG, which can add a card without a working key, or CLIP for coding. Some users recommend attempting to repair the old card or using a pre-coded transponder with CARPROG. The cost of obtaining a new key in Norway is noted to be around 2500 PLN. The user later reports successfully fixing the card through electronics repair.
