Lenovo Laptop with Windows 8.1 Unable to Connect to AndroidAP Hot Spot from Samsung S5
Xerxex 7362 6
  • #1 16233247
    Xerxex
    Rate: 141
    Hello, I wanted to connect the internet in the form of a hot spot to share internet from my phone, i.e. samsung s 5 on an older laptop with widnows 7 internet automatically connects and I can surf without problems. However, I also want to be able to use the internet on a Lenovo laptop with Windows 8.1 and here a huge problem arises because the system sees the AndroidAP network enters the password for the connection and the information is connected but the internet does not work. Then several times the information appeared "limited" and I can't connect to the internet. After the problem is diagnosed, the DNS server not responding message appears. When connecting to your home network, wifia works without a problem. Please advice how to fix this problem.
  • #2 16234106
    actin
    Help: 187
    Rate: 799
    In the HOTSPOT settings on your phone have you tried to add a second laptop as an allowed device?
  • #3 16234226
    Xerxex
    Rate: 141
    In the phone with connected devices I have the name latopa and its ip also looks like the phone is connected to the laptop also in the laptop I have information that it is connected (AndroidAP Connected) internet 3 lines of connection but no internet in the browser.
  • #4 16234321
    actin
    Help: 187
    Rate: 799
    And this happens when an old laptop is also connected? Is it only when you have a new one connected?
    Have you tried adding new to allowed devices?
  • #5 16234724
    Xerxex
    Rate: 141
    This only happens in a new laptop in an old one without a problem.
  • #6 16234844
    actin
    Help: 187
    Rate: 799
    You still haven't written or tried to connect by adding your laptop to trusted devices
  • #7 16256643
    Xerxex
    Rate: 141
    Solved topic I added a laptop to trusted and after the problem. Thank you.
A user experienced difficulties connecting a Lenovo laptop running Windows 8.1 to a Samsung S5 mobile hotspot, while an older laptop with Windows 7 connected without issues. The Lenovo laptop recognized the hotspot and accepted the password, but displayed a "limited" connection with no internet access, accompanied by a "DNS server not responding" message. After troubleshooting, it was suggested to add the Lenovo laptop to the list of trusted devices on the Samsung S5. This solution resolved the connectivity issue.
