Xiaomi S2 Hotspot Issue: Android 8.1 MIUI Global 10 - Connected but No Internet Access
darekwilno 6747 2
  • #1 17573365
    darekwilno
    I have android 8.1 MIUI Global10
    I turn on the hot spot and check on my laptop, I manage to connect to the phone, but I don't have internet. From the phone I can see that the laptop is connected. I turned off the Caspian on the laptop.
    What could be the reason?
  • Hotspot works after toggling mobile data during use
    #2 17573423
    Steryd3
    Help: 241
    Rate: 301
    I have a similar case in xiaomi Redmi Note 5.
    I figured it out half a day, I read the forums ... it seems that the software of the phone is to blame. After upgrading to version 10, it stopped working. No one had a specific working solution on the net.
    It turned out that everything starts working when data transfer from the GSM network is restarted during HOTSPOT (switch it off and on again).
    It works without it but only the "client" which is another xiaomi phone (I checked because my wife has).
    I need to check if the situation has improved because I am after the upgrade to the next version.
