Kia Ceed 1.6 Dashboard Lights: Key Indicator, Immobilizer Malfunction, Error Codes & Solutions
magda77000 8433 3
  • #1 16233458
    magda77000
    First, the indicator with the key came on, which indicates a malfunction of the immobilizer. The car started without any problems. I drove to the mechanic, connected the car to the computer and began to pop up a lot of errors. Among others battery charging. Therefore, it was mentioned especially that the previous one was new. Immediately after the replacement, the brake indicator appeared and the indicator light with the key began to flash. I replaced the pads and the fluid was checked (everything OK) and the candles were replaced. The indicator first disappeared and then started flashing to appear again. The car went to an electrician, who said that it is probably a failure of the displays. Unfortunately, this has been excluded. And now there are two more lights: belts and doors.
    Do you have any ideas?
  • #2 16233486
    cezars65
    Help: 53
    Rate: 282
    The problem lies in the computer controlling the operation of the electrical installation and managing the CAN bus.
  • #3 16233548
  • #4 16233875
    magda77000
    Will I therefore have to visit the KIA website? How much can such a service cost? Do I have any other alternatives?
