KIA Ceed 2009 Power Steering Issue: Failure Light On, MOBIS vs TRW, 24c16, Relay & Connectivity
Pfemek 11973 3
  • #1 17269994
    Pfemek
    Help: 83
    Rate: 342
    Ceed with broken down support. The failure, power, etc. light is on. MOBIS support but looks identical to the TRW from the modus. Also 24c16 inside. The question is this could be a problem with the charge? Anyone had a similar topic? Electronics looks ok. Transistors are ok. However, it does not turn on the main relay after starting the engine. Launch does not connect with this support but I do not know if it is the scanner's fault or it is a fault.
    Attachment in the attachment.
    • 24c16 uszkodzone.zip (1.06 KB) You must be logged in to download this attachment.
  • #2 17270651
    seat21
    Help: 151
    Rate: 399
    Connect with something else, e.g. cdp does it, Launch once didn't want to calibrate me and cdp from the arrow
  • #3 17272779
    nubi
    Rate: 20
    In the company KDS you also often have to mark what system we have, whether TRW or Mobis, incorrect selection is a lack of connection, but it is in newer KIA models. In these aids, 90% of defects are a steering angle sensor resulting in the replacement of the MDPS with the column. If, however, you suspect that soft has spilled, there are updates introduced to these modules.
  • #4 17289696
    Pfemek
    Help: 83
    Rate: 342
    Car repaired. Established stimulant and works from the arrow. Now launch connects easily.
    Thanks for the hints.
    Best regards...
