WD500BPVT HDD 500 GB Password Reset: Incorrect Password Issue & Key 74189076 - Western Digital
arojda 10971 14
How can I unlock or remove the password on a WD500BPVT HDD after setting too short a password and now being asked for an unlock key?
You cannot bypass the ATA password directly, and a password shorter than 7 characters was likely accepted incorrectly or replaced by a random one from the BIOS [#16235805][#16236054] After 3 wrong attempts, use the drive’s unlock key and generate the matching password on bios-pw.org; in the thread, key 74189076 was used that way [#16236684] Once the generated password was entered, the disk status changed to Frozen, which prevented the password from being activated again and allowed the installer to format the drive [#16236684][#16236711] If you want to work from another system, the suggested method was to connect the HDD as an additional data drive, preferably via SATA or with a SATA-to-USB adapter, and use HDD Unlock Wizard to remove the password [#16236054][#16236421][#16236570] In the end, the user reported that everything worked and the problem was solved [#16236820]
  • #1 16235767
    arojda
    I have a problem with a 500 GB WDC WD500BPVT HDD. When changing the password from the previous one, I set the password "1" so that I could not write the long password I had previously set up every time. To my surprise, when restarting the computer it turned out that the password is incorrect. Is there any way to determine what the current password is? Hard disk formatting is at stake because I don't have any important data there. I know that twmat has been discussed many times but I have not found the answer. I will add that my password key is 74189076. Regards and hope for help.
  • #3 16235941
    arojda
    The previous password is not valid. I checked
    dzimen11
    Rate: 8
    It seems like Bios gave you a random password if you gave the type "1" too short. If you have another computer, you can use the HDD Unlock Wizard. You connect a disk and this program is able to remove the password from the disk.
  • #5 16236323
    arojda
    I need to connect this disk to another usb? I read that the adapter has problems detecting the disk.
    dzimen11
    Rate: 8
    Do not connect it to your computer normally via a sata connector. The computer should detect the additional disk.
  • #7 16236566
    arojda
    Unfortunately, I only have one more laptop. Both laptops have only one SATA connector. I tried to replace the disk in a second laptop, unfortunately the same problem occurs. Would it be a good idea to install windows on an external disk, start the operating system from this disk and then run the above program?
    dzimen11
    Rate: 8
    You can do it, but it's a bit of a job. Do you have a sata to usb adapter? Then when you connect the disk via usb it will be detected as a data carrier and then the program should also detect it
  • #9 16236588
    arojda
    I don't have an adapter. After that I read that it doesn't always detect the disk. I will try to do as I wrote earlier. I'll let you know how it went.
  • #10 16236598
    dzimen11
    Rate: 8
    You can still connect 2 laptops to each other or a desktop with a laptop using a USB or Ethernet cable. From what I associate, this program also has the option of detecting a disk
  • #11 16236684
    arojda
    After entering the wrong password 3 times, he asked for the password for the key.
    https://bios-pw.org
    On this page I have generated a password for my key. The password status in Bios has been changed to Frozen. Unfortunately, windows did not start, but the intalator could format the disk. I'm starting with the new windows installation. I will let you know if everything works correctly and the installation is finished. I will add that earlier the installer showed a message that I do not have permission to format the disk.
  • #12 16236711
    dzimen11
    Rate: 8
    https://bios-pw.org
    Strange that Windows did not start immediately because I can honestly say that if the password is frozen then the system should start. Now you will definitely be able to format because the password is frozen. At first you couldn't avoid it because the password bothered
  • #13 16236790
    arojda
    Everything works as it should. Is it possible for a password that is frozen to be activated without a default setting in Bios or is it rather not possible?
  • #14 16236818
    dzimen11
    Rate: 8
    It shouldn't be activated by itself. I'm glad everything works.
  • #15 16236820
    arojda
    Thank you for your help then. Problem has been solved. Subject to close.
The discussion revolves around a user experiencing an incorrect password issue with a 500 GB Western Digital WD500BPVT HDD after attempting to reset the password to a simple "1". The user confirmed that the previous password was invalid and sought solutions to recover access to the drive. Responses suggested that the BIOS may have assigned a random password due to the short length of the new password. Recommendations included using HDD Unlock Wizard on another computer or connecting the HDD via a SATA to USB adapter. The user faced challenges with hardware connections but eventually managed to generate a password key and change the password status to "Frozen", allowing for disk formatting and a new Windows installation. The issue was resolved successfully, and the user expressed gratitude for the assistance received.
