Mercedes vito 639, 111cdi, 2005, weak parking brake (pads, discs ok)
arturo3791 13059 5
  • #1 16236647
    arturo3791
    Hello, maybe someone will help how to adjust the parking brake, I only keep the pedal pressed as far as it will go (new pads, discs ok)
    Dziarski Hank
    Help: 246
    Rate: 935
    Because the parking brake works like a disc-drum on the rear and jaws. The mechanism is the same as in almost every MB - linings attached to the anchor disc, at the bottom a spreader connected to a rope, at the top an expansion screw with adjustment. As with steel wheels, it is enough to unscrew one screw for adjustment and locate the expansion screw with a flashlight. Use a wide, flat screwdriver to turn it until the lining is correctly positioned. If the mechanism has never been moved, it is often necessary to unscrew the caliper, remove the rear disk and disassemble and lubricate the mechanism components, only then to make the adjustment.
  • #3 16241454
    arturo3791
    Thanks for the hint, today I will take on this adjustment, I have alloy wheels and discs on the back, I probably have to throw off the wheel and look for this adjustment as you say at the top with a screwdriver and the same on the other side of the wheel because I understand that the adjustment is separate for each wheel.
    figaro11
    Help: 10
    Rate: 19
    Hello. A colleague described the manual adjustment well for you, I want to add that there is one more adjustment in the vitku. It is under the car in the rear part, in the place where the cables spread to both wheels, if the cables have never been replaced, they are certainly stretched and even tightening with the adjuster at the jaws will not help. If the adjustment at the jaws does not help, look for where I wrote, there probably is a key nut 13 there and try to shorten the stroke of the line, if it will not help replacing the lines with new ones. Best regards and I wish you successful regulation.
  • #5 16241485
    arturo3791
    Thank you very much ! I will work today.
    Best regards.
  • #6 16266964
    arturo3791
    Thanks to everyone for helpful hints.
    Problem solved.
    Best regards.
