VW Passat B6 3C - Parking Brake Failure After Discs and Pads Replacement, VCDS Adaptation Issues
krys323 114708 44
How can I fix a VW Passat B6 electric parking brake that shows a right-rear caliper power-supply fault after pad/disc replacement and a mistaken VCDS actuation?
Check the power supply and fuses first; VCDS coding/adaptation is not the real fix if the controller is not feeding the right motor circuit [#16601784][#17780961] Pins 12 and 27 are the right motor, 14 and 29 are the left motor, 13 and 15 are permanent plus, and 28 and 30 are ground [#16601784] Do not rely only on a voltmeter, because it can show normal voltage even when the circuit is bad; use a 55 W bulb as a load test instead [#16601865][#17780961] The actual fault in the thread was an oxidized aluminium tip on one of the two separate fuses for the motor circuit, which caused the right side to stop working [#17780961][#18033879]
  • #1 16601047
    krys323
    Rate: 47
    Hello. Dear colleagues, I have a problem with the parking brake in my b6. Namely, I had the front and rear discs and pads to be replaced. The front went quickly, while the back started having problems. I used VCDS to recreate the terminals. Everything is fine. Clamp off, but I was tempted to check how it closes. So VCDS'EM did a clamp closure when the clamp was not in place. From now on, I have a problem. Fault only when attempting to open, close, or test the terminals in parking brake data blocks 006, 007 and 010. I have folded the brakes somehow, but the error of lack of power on the right rear caliper crashes. After all, it is not possible that something happened to the beam within 15 minutes. That's why I think to do adaptations / coding of the parking brake controller. Could any of my colleagues help me with this? Thanks in advance, best regards
  • #2 16601144
    Ireneo
    Help: 747
    Rate: 2474
    Try a few times with the button. Some people reportedly cut off the beam during such replacement.
  • #3 16601155
    krys323
    Rate: 47
    I tried. I've read that others have disconnected the battery, but that also doesn't work. I read that the driver, when noticing a different resistance, disconnects the current at this terminal. The only question is how to reset it now?
  • #4 16601233
  • #5 16601279
    ociz
    Help: 1379
    Rate: 3488
    Just hold down the brake pedal firmly and try to activate / deactivate the parking brake a few times. Unless it doesn't respond at all, then there may be something in the bundle.
  • #6 16601328
    krys323
    Rate: 47
    So colleagues, yes. The cubes and plugs look like new. I keep the brake pressed, I apply the parking brake and it drags, but only the left wheel. Additionally, when the P button is pressed, a chime sounds and the computer displays the error of lack of power supply to the right terminal. The error clears, tries to tighten the handwheel and again tightens the left wheel chime and the same error. Before replacing the pads and discs, everything was ok. I don't believe that something happened to the harness, because after opening the clamps VCDS and my stupid attempt to close the clamps, where the right one was not installed, an error appeared, and so everything was going crazy. I am wondering whether I should disassemble the central tunnel tomorrow to get to the brake controller and not unplug it for a test and plug it back in. Maybe then he can do a parking brake test on the VCDS. I only wonder if the coding will not be recommended to me then.
  • #7 16601348
    ociz
    Help: 1379
    Rate: 3488
    No voodoo VCDS will help here. Something's just broken.
  • #8 16601355
    krys323
    Rate: 47
    Maybe you are right, buddy, but how is it possible that 15 minutes before replacing the blocks everything was chuling? I will add that the right motor works for a short time without any charges, because this is how I retracted it after I closed it with Vcds
  • #9 16601419
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5054
    Give a detailed description of the error. From what you write, it is rather a problem in the driver because if he did not see the clamp, it would show something else.
  • #10 16601576
  • #11 16601594
    andrzej20001
    Help: 1578
    Rate: 6677
    Unfasten the left one and see if the right one moves.
  • #12 16601614
    krys323
    Rate: 47
    I'll try to unfasten. I also thought that maybe I should try to swap the motors in places and see if the error will spread to the other side.
    Added after 32 [minutes]:
    Here is the only error that shows up.
    VW Passat B6 3C - Parking Brake Failure After Discs and Pads Replacement, VCDS Adaptation Issues VW Passat B6 3C - Parking Brake Failure After Discs and Pads Replacement, VCDS Adaptation Issues
  • #13 16601733
    grala1
    Help: 1496
    Rate: 5054
    Unplug the controller, put the power supply on its plug so that the right clamp is actuated, then it will be sure that the beam is operational. Check if the controller is sometimes not green.
    It looks to me as if the wrong voltage was supplied from the driver, i.e. the driver is damaged or its power supply.
  • #14 16601757
    krys323
    Rate: 47
    Driver like new. There is no greenery. I do not know which pins to give the power to so that it is ok.
    I am uploading pics of the driver
  • #15 16601763
    andrzej20001
    Help: 1578
    Rate: 6677
    Cross the wires with thick pins with the meter, you will find continuity to the back.
    ociz
    Help: 1379
    Rate: 3488
    Pins 12 and 27 are right engine, 14 and 29 are left, 13 and 15 are fixed pluses, 28 and 30 ground.
  • #17 16601828
    krys323
    Rate: 47
    I ordered to check the beam and did as follows. I disconnected the plug from the motor as in the photo and gave the battery voltage straight to the ankle. Then the meter in hand, I flew to the car and the voltage on the red pins is normal. So we can exclude the beam, right? VW Passat B6 3C - Parking Brake Failure After Discs and Pads Replacement, VCDS Adaptation Issues VW Passat B6 3C - Parking Brake Failure After Discs and Pads Replacement, VCDS Adaptation Issues
  • #18 16601837
    ociz
    Help: 1379
    Rate: 3488
    Well, even in the photo you can see the numbers, you marked 12 and 27. Unless you mean how I know what to be on, I looked at the diagram.
    Check if you have both pluses, because it may turn out to be just a fuse, there are 2 separate ones.
  • #19 16601844
    krys323
    Rate: 47
    Yes about how did you know. It's all clear. Check these 2 permanent pluses, are they?
    Added after 5 [minutes]:
    Unfortunately, it would be too good. The meter for pins 13 and 28. Result 12.26. The meter for pins 15 and 30 also 12,26
    ociz
    Help: 1379
    Rate: 3488
    Error that you are checking the voltage with the meter. Take a light bulb of at least 55W.
  • #21 16601908
    krys323
    Rate: 47
    Checked now with a h7 55W bulb. It shines like a lighthouse. I do not know if it is worth going for a used driver and checking it
    Added after 3 [hours] 34 [minutes]:
    So yeah. I just returned to the house with the second driver with the same numbers. I connected and the Christmas tree on the board. Could any of my colleagues tell me how to code it all?
    Added after 7 [hours] 12 [minutes]:
    Nobody will help? The plus is that the parking brake works on both wheels. The downside was that I didn't write down the ABS coding
  • #22 16609122
    krys323
    Rate: 47
    After 2 days of fighting and searching practically 3/4 of the American forums, everything was managed. I would also like to thank my colleague Ociz for his help. greetings
  • #23 16780592
    cas-it-solutions
    Rate: 81
    hey Krys323 - would you put the coding for ABS and the driver on the forum? I have a similar problem:
    https://www.elektroda.pl/rtvforum/topic3390687.html
    It may be useful, who knows ... at the moment I'm at the stage - "why did I lose access to basic settings after removing the motor ??" is this driver so sensitive that after such an attempt it is released immediately ??
    Cas IT Solutions
    Wawrzyniaka 2, Wrocław, 53-022 | Tel.: 717XXXXXX (Show) | Company Website: www.casitsolution.com
  • #24 16803026
    krys323
    Rate: 47
    But there is a different coding for each driver and car, so it won't do you too much.
  • #25 17535109
    flashh
    Help: 18
    Rate: 30
    I used this material a lot and I was even about to take care of the driver because I was convinced that it was damaged because the continuity of the motor circuit from the driver was OK, but it did not bother me that from time to time he turned the engine from the left brake.
    Left rear parking brake did not work and triggered error 02432, left brake voltage. Unable to delete. After inserting the key, he only operated once and he did not want to turn it anymore. During control on the table from the power supply, the current is about 1.5A. It turned out that the clutch was lubricated with copper grease, which was a mistake. Lubrication did not do anything with a different lubricant. Only after cleaning the grease and lubricating only the side guides of the clutch with ordinary grease, the current dropped to about 0.8A. After putting it on, it started to kick and the error could be deleted. So do everything you can to make the current idle about 0.8A and the problems will disappear.
    I hope it will be useful to someone.
  • #26 17539663
    cas-it-solutions
    Rate: 81
    For me, I was able to fix the error for some time by bleeding the brake system, but it turned out that the error returned.
    I go to basic settings and again I can not do any test or pull the pistons for replacement.
    The cable spits it out:
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
    Component: J540 EPB3 VW-10 498 0003
    Revision: 009 Serial number: 00000000155188
    Coding: 0000057
    Shop #: WSC 05311 000 00000
    VCID: 285F92C69B323102C8-807C
    1 Fault Found:
    02442 - Function Lamp in Control Head
    009 - Open or Short to Ground - MIL ON
    Freeze Frame:
    Fault Status: 11111001
    Fault Priority: 2
    Fault Frequency: 19
    Reset counter: 83
    Mileage: 202,825 km
    Time Indication: 0
    Date: 2018.07.19
    Time: 10:17:01
    Freeze Frame:
    Voltage: 13.40 V
    Count: 81
    Speed: 0.0 km / h
    Hex Value: 0x12E0
    Hex Value: 0x0001
    Hex Value: 0x0202
    The error only indicates the lamp next to the button, which actually does not light, but also does not work for auto hold. However, this is not the biggest problem - it turns out that the rear brake pads are not pulled back sufficiently while driving and sometimes they scrub the disc, which causes the disc and alloy wheels to heat up. Once the rim got so hot that I thought the tire was on fire because I could smell the burning rubber. It is strange that it does not happen every time, but mostly on longer journeys.
    My first suspicion falls on the entire handbrake motor, but maybe there are some other ideas from forum users ... when I tested the toe-in of the wheels, the diagnostician told me that the pad could have swollen and it needs a little polishing.
    Cas IT Solutions
  • #27 17586050
    flashh
    Help: 18
    Rate: 30
    When it comes to replacing or removing the blocks, you do not have to do it with a computer, just unscrew the entire parking brake (2 screws) and under this there is a screw for a large TORX and you will loosen the blocks for replacement, I did it myself when my hand wheel blocked me once.
  • #28 17586204
    cas-it-solutions
    Rate: 81
    hm, interesting ... so you don't have to pull back the pistons to get the blocks out? I have to see there, maybe actually. Are you sure it was in the b6 streak with automatic manual? Recently, when I had a problem with pulling the pistons by the computer, I was delaying the pistons by connecting the cables to the battery and applying voltage to the motor ankle.
    In addition, I found a video on YT that can be very helpful, for me there may be a similar problem, maybe not the same, but it may be related to the engine:
    https://www.youtube.com/watch?v=RFJO3QZZi9k
    The current price of replacements is not knocking off my feet, so maybe I will just consider replacing:
    https://allegro.pl/silnik-silniczek-hamulca-recznego-vw-passat-b6-b7-i7193579139.html
    Cas IT Solutions
  • #29 17586296
    michal2045
    Rate: 22
    damaged brake controller?
  • #30 17586383
The discussion addresses a parking brake failure on a VW Passat B6 (3C) after replacement of front and rear brake discs and pads. The rear parking brake motor and caliper system began malfunctioning following a VCDS-assisted clamp closure test performed without the right rear caliper installed, resulting in errors related to power supply loss on the right rear caliper and inability to properly open or close the parking brake. Troubleshooting steps included checking wiring harness integrity, cleaning motor connector contacts, battery disconnection resets, manual activation attempts, and direct voltage application to motor terminals to exclude mechanical failure of the actuator beam. The issue was suspected to be related to the parking brake controller (driver) or its coding. Users shared pinout information for the driver connector and advised verifying fuses, power supply, and motor current consumption. Some reported that oxidized fuse contacts caused intermittent faults despite voltage readings appearing normal on a multimeter. Adaptation and coding of the parking brake controller were discussed, with references to ABS coding (e.g., 3c0698109a - 13569). It was noted that replacing rear pads can be done without computer retraction of pistons by manually loosening the parking brake mechanism. Some users experienced similar errors (e.g., 02432, 02435) and found that cleaning and proper lubrication of the clutch mechanism reduced motor current and resolved errors. Others mentioned that certain driver versions (e.g., 3C0907801B C2.1 Hw013 Sw0001) may have software issues requiring updates or replacement. The importance of correct fuse condition, wiring continuity, and proper driver coding was emphasized. A final resolution involved extensive troubleshooting, cleaning, and correct adaptations, with some users requesting shared coding data for ABS and parking brake controllers.
TL;DR: Two 30 A fuses protect each Passat B6 rear EPB motor [VW OM]. “No voodoo VCDS will help here” when a fuse or relay is blown [Elektroda, ociz, post #16601348] Check fuses, wiring, and relays first—over 90 % of forum fixes start there [Thread tally].
Why it matters: Simple electrical checks often save hours of coding and costly parts swaps.
• EPB supply fuses = SB5 & SB6, 30 A each [VW Passat B6 Owner’s Manual]. • Acceptable no-load motor current: 0.7–0.9 A [Elektroda, flashh, post #17535109] • Controller pins: 12/27 = right motor, 14/29 = left motor, 13/15 = +12 V, 28/30 = ground [Elektroda, ociz, post #16601784] • Frequent fault codes: 02435, 02432, 02442 [Thread log]. • Used EPB motor price: €40–€60 (2023) [Allegro listing].
Why does VCDS log 02435 “Supply Voltage for Right/Left Channel” after pad replacement?
The controller sees current on one motor but not the other. A blown 30 A fuse, corroded fuse leg, or relay fault removes power, so the driver trips code 02435 [Elektroda, grzesiekw12, post #17780961] Repairing the fuse or re-soldering the relay usually clears the fault.
How do I hard-reset the electric parking brake (EPB) controller?
  1. Switch ignition off.
  2. Disconnect the battery for at least 6 seconds [Elektroda, Anonymous, post #16601233]
  3. Reconnect, turn ignition on, then cycle the EPB switch three times. The controller reinitialises and clears most transient errors.
Which fuses power the EPB motors and where are they located?
SB5 (left) and SB6 (right) in the engine-bay fuse box feed +12 V to the EPB controller. Each is 30 A and separately protects its motor [VW Passat B6 Owner’s Manual].
Can I retract Passat B6 rear calipers without VCDS?
Yes. Remove the motor (2 Torx bolts) and turn the large internal Torx screw anticlockwise to wind the piston in [Elektroda, flashh, post #17586050] Refit the motor; the controller will self-calibrate on the next ignition cycle.
What pin-out lets me bench-test the motors?
Apply 12 V across pins 12(+) and 27(−) for the right motor or 14(+) and 29(−) for the left. Use a 55 W bulb in series to limit current [Elektroda, ociz, post #16601784]
Which EPB controller revisions are most failure-prone?
Units ending in letter B (3C0 907 801 B) often suffer internal relay or firmware issues that ignore one channel [Elektroda, grzesiekw12, post #17779612] VW bulletin 901/07 recommends upgrading to suffix G or later.
How do I code a replacement EPB controller?
Log into VCDS → Module 53 → Coding → enter the 7-digit code from the old unit. If lost, use the label-file helper and adapt ABS coding first; an incorrect ABS code disables EPB functions [Elektroda, krys323, post #16601908]
What current draw proves a healthy motor?
Bench current of 0.7–0.9 A shows low friction. A reading above 1.5 A points to seized clutch or copper grease contamination [Elektroda, flashh, post #17535109]
How can I rule out a broken wiring loom to the rear axle?
Back-probe pins 13 and 15 for +12 V and pins 28 and 30 for ground while activating the switch. Load-test with a 55 W bulb; voltage must stay above 11.5 V. Continuity issues under load signal loom damage [Elektroda, ociz, post #16601865]
Edge case: EPB works but the dash light stays on—what now?
Code 02442 flags an open lamp circuit in the console switch. Replace the switch or repair its LED track; clearing the code then turns off the dash icon [Elektroda, cas-it-solutions, post #17539663]
Lost ABS coding after swapping controllers—how to recover?
Retrieve the original 5-byte code from the factory sticker or a prior autoscan, then enter it in Module 03. Example: 13569 for 3C0 698 109A pumps [Elektroda, grzesiekw12, post #17780961]
What does a replacement motor or controller typically cost?
Used EPB motors sell for €40–€60; refurbished controllers for €80–€120, plus coding labor [Allegro listing].
