Lenovo Miix 300: Momentary Charging Animation, Battery Not Charging - Software or Hardware Issue?
rafal19052 5121 6
  • #1 16236732
    rafal19052
    After connecting the plug there is a momentary animation of charging but the battery does not charge, it discharges normally. Detects connected charger. The charger has the correct voltage. Software fault or hardware damage?
  • #2 16236760
    dzimen11
    Rate: 8
    Check if the voltage goes into the battery (undress the laptop and check the voltage at the power socket)
  • #3 16237415
    rafal19052
    Unfortunately, there is no voltage, the computer does not see the tablet when connected to the micro usb connector on the side. Maybe someone tried to charge the tablet via micro usb, could it damage it? The tablet has a separate charging socket.
  • #4 16237696
    dzimen11
    Rate: 8
    Rather, it did not cause the specified fault. It is also worth checking the battery voltage if it is working at all
  • #5 16237754
    rafal19052
    The battery charges when the tablet is turned off, but it takes too long after 5 hours of charging it is 23 percent charged. The battery is rather efficient and discharges at a normal rate.
  • #6 16237943
    dzimen11
    Rate: 8
    There must be some minor malfunction on the motherboard. One of the controllers or integrated circuits may be damaged. Alternatively, the power supply has voltage drops.
  • #7 16252457
    rafal19052
    I went away to the service, they found no damage, they charged fully, they ordered me to buy a better charger. I bought a 5v tracer 3.4 And when it was about 80 percent charged it was charging normally. and doesn't load.
The Lenovo Miix 300 is experiencing a charging issue where a momentary charging animation appears, but the battery does not charge and discharges normally. Initial checks revealed no voltage at the battery connection, and the device does not recognize the micro USB connection. The battery charges slowly when the tablet is powered off, indicating potential issues with the motherboard or power supply. A service visit found no damage, but a recommendation to use a better charger led to improved charging performance when a 5V tracer charger was used.
