[Solved] Lenovo Yoga TAB 3 10 (YT3-X50L) Battery Not Charging: Replaced Cells, NCR18650B & NCR18500A
martiv 36438 16
Why does a Lenovo Yoga Tab 3 10 (YT3-X50L) show 0% charging and shut down after replacing the battery cells?
The problem is most likely in the battery pack electronics/BMS rather than in the cells alone; after cell replacement the gauge may need a reset, and the replacement cells should be perfectly matched and charged to the same level before assembly [#17427981] The battery PCB in this pack uses a bq27541-type fuel gauge / lithium-ion battery level indicator [#18395325] One reported fix was to desolder the BMS, discharge the cells, charge them externally to about 3.7 V, then solder the BMS back; after that the tablet started charging normally [#18393454] If you still see 0%, check the battery electronics and not just the cell voltage at the connector [#17427981]
  • Battery pack voltage present but tablet reports 0% charge
    #1 17424283
    martiv
    Help: 22
    Rate: 41
    Hello colleagues,
    I have a problem with the Lenovo Yoga TAB 3 10 tablet model: YT3-X50L.
    He came to me completely dead, despite connecting charging did not respond.
    I held it on the power supply for several hours and strangely got up, unfortunately the battery was weak and did not hold long, so I decided to regenerate it because it is nowhere available.
    I replaced all cells 3pcs NCR18650B 2x and one piece NCR18500A, assembled battery as it should be and put it in the tablet. He charged the battery to 100%, kept it nice until. The next day he stopped charging. There is an inscription: Loading: 0%. Attempt to turn on: the tablet starts up, the android will load, after a while it goes off and returns to charging (0%). Advice where to look for a problem.
    I measured the batteries, the voltage that comes out of the battery connector is 4.10V.
    The worst thing is that everything was fine, loading, working on the tablet.
    ABCLAP
    Trockiego 43, Kraków, 30-394 | Tel.: 510XXXXXX (Show) | Company Website: https://www.abclap.pl
  • #2 17427981
    gradek83
    Help: 930
    Rate: 2103
    And it is not that the new cells must be properly prepared, i.e. perfectly charged, and their capacity theoretically the same. In addition, the electronics of the battery controls their charge and after replacing the cells must be reset .... Unless I'm mistaken, the battery manufacturers protect themselves and set the maximum allowable number of charging cycles after which the management system stops charging.
    Check the battery electronics. Maybe you will find information ... anyway, even if you have a device that reads data from such a system and having the ability to change settings, sometimes the system itself is protected by a password and then it is already sweeping ...
    What markings do you have on the battery casing, send the picture somehow I don't want to believe that there is no battery for this equipment.
  • #3 17428026
    martiv
    Help: 22
    Rate: 41
    Thanks for the info, the layout that sits in electronics is bq7541 the rest cannot be read even under a microscope. All in all, I did not think about loading all cells into the full body and only assemble the battery.
    This is Lenovo yoga Tab 3 10, YT3-X50L designation on the L15D3K32 X50 battery.
    I found it but used it, I wanted to regenerate it and everything was ok. if it were new I would buy it: /
    ABCLAP
  • #4 17428125
    gradek83
    Help: 930
    Rate: 2103
    EV2400 and one can have fun but it costs a bit. These so that they don't fold sometimes?
  • #6 17707205
    Mareeek_89
    Rate: 17
    martiv have you managed to deal with the problem?
    I have a similar case. The same model Lenovo YT3-X50L. I got it as a gift, so I don't know its history.
    when connected to a charger, shows that it is charging, but the level still displays 0%. When you try to start the tablet gets up, it boots, android starts and the message pops out that the battery is low and turns off.
    I took out the batteries to verify and here I have 4.2V on the output, i.e. full. 4.2V on each cell
    I would like to point out that my battery was not regenerated, everything was original.
    When I start the tablet by entering the service menu, it does not reset, it remains turned on all the time.
    any suggestions?
  • Lenovo tablets stop charging after USB connector damage
    #7 18393292
    bacaking
    Help: 5
    Rate: 20
    I'm joining a thread.
    I already have three such cases and only at Lenovo.
    1. TB-X605F - broken USB-C connector. Solder connection charging works. The charging light on the tablet is on. Shows on the display that it is charging but all the time 0%. As I check on the laboratory power supply, until the tablet does not signal charging the current from the power supply is 0.45A but when the tablet shows on the display the charging current drops to zero. No wonder it doesn't load, but why does it happen? after disconnecting the power supply it does not go out immediately - that is, there is some voltage in the battery.
    2. yt3-x50F - exactly the same - it came to me with a torn out USB connector.
    3. yt3-850L - also not charging but this for a change displays the message "battery temperature too low - charging aborted" or something like that.
    If anyone has any suggestions, I will gladly accept.
    Such miracles are only from Lenovo
  • #8 18393454
    Mareeek_89
    Rate: 17
    In my case, I desoldered BMS from the battery.
    I discharged the battery cells and charged it with an external charger to around 3.7V
    I soldered the BMS and it started charging normally.
    It seems to me that BMS just after desoldering simply reset and it helped, but this is supposition. In any case, the tablet works and charges normally until now.
  • #9 18395193
    bacaking
    Help: 5
    Rate: 20
    Thus...
    I desoldered BMS. I have charged the battery to 16% with external power supply. I soldered BMS but no charging. I desoldered BMS again and measured the voltage at the BMS output on the battery with power connected to the tablet - the power jumps to 4.3V and drops / stops charging over and over again. I don't have a BMS to substitute for. Maybe someone knows how to check it?
  • #10 18395325
    gradek83
    Help: 930
    Rate: 2103
    martiv wrote:
    bq7541
    So bq27541
    "One-chamber lithium-ion battery level indicator for battery integration"
    So the system reading the total voltage on the batteries.
    There is no other layout there, send a photo of the PCB from both sides
  • #11 18395820
    Mareeek_89
    Rate: 17
    Lenovo_YT3-X50L
    Lenovo Yoga TAB 3 10 (YT3-X50L) Battery Not Charging: Replaced Cells, NCR18650B & NCR18500A Lenovo Yoga TAB 3 10 (YT3-X50L) Battery Not Charging: Replaced Cells, NCR18650B & NCR18500A
    Lenovo_1051L
  • #12 18533069
    Python013
    Rate: 18
    And did your colleague check before how did the pins look inside?
    Personally, I have such a Lenovo tab M10 on the table and the pads are torn out so I have nowhere to solder the USB-C port and I am looking for a service manual, but from the other side of the port the pins were crossed and it was through the plug of the charger cable so some charging-related systems could go banking.
    • Lenovo Yoga TAB 3 10 (YT3-X50L) Battery Not Charging: Replaced Cells, NCR18650B & NCR18500A Snapshot000000.jpg (60.59 KB) You must be logged in to download this attachment.
  • #13 18617540
    Pstryk20
    I have such a problem that I do not load I thought that the plug but I have two the same tablets I transferred to the other and it's ok batteries I also rescheduled and it is also ok and loading so something is with the disc that does not load what I can do and where to look.
    Thanks in advance and regards
  • #14 18617639
    nutergsm
    Help: 1034
    Rate: 1665
    Charging socket to check.
  • #15 18617788
    Pstryk20
    The socket is checked ok and the battery is checked ok
  • #16 18665887
    chajniq
    Rate: 15
    Which battery circuit is this bms?
  • #17 18856750
    martiv
    Help: 22
    Rate: 41
    The problem could not be resolved. The tablet has been returned to the customer. We are closing the topic.
    ABCLAP
The discussion revolves around issues with the Lenovo Yoga TAB 3 10 (YT3-X50L) tablet, specifically regarding battery charging problems after cell replacement. The user initially received a non-responsive tablet and attempted to regenerate the battery by replacing the cells with NCR18650B and NCR18500A types. After reassembly, the tablet charged to 100% but subsequently displayed a charging status of 0%. Various responses suggest checking the battery management system (BMS), ensuring proper cell preparation, and verifying the integrity of the charging port. Some users reported similar issues with other Lenovo models, indicating potential common faults. Solutions discussed include desoldering and recharging the BMS, checking for voltage inconsistencies, and examining the USB-C connector for damage.
TL;DR: Lenovo Yoga Tab 3 10 charging stuck at 0%? One case drew 0.45 A until the tablet “current drops to zero”. Try BMS reset, port checks, and cell prep before board work. [Elektroda, bacaking, post #18393292]
Why it matters: This FAQ helps DIY repairers and techs diagnose Lenovo YT3‑X50L no‑charge faults and choose fixes that work.
Why does my Lenovo YT3‑X50L show 0% and shut down even with charged cells?
Because the pack electronics may be latched or misreporting state of charge. One owner measured 4.2 V per cell, yet the tablet stayed at 0% and shut down. This symptom points to the battery pack needing attention or reset. Entering service menu kept it on, confirming software boots. [Elektroda, Mareeek_89, post #17707205]
How do I reset the Yoga Tab 3 battery BMS/gas gauge?
Try a simple re‑initialize.
  1. Desolder the BMS PCB from the pack.
  2. Discharge or charge the cells externally to around 3.7 V.
  3. Resolder the BMS and test charge on the tablet.
After this, “it started charging normally” for one owner. Handle cells safely and avoid shorts. [Elektroda, Mareeek_89, post #18393454]
What chip manages the battery, and what does it monitor?
The pack uses a TI bq27541 fuel gauge on its PCB. It measures single‑cell voltage and reports state of charge. As one expert noted, it is “reading the total voltage on the batteries.” If the gauge is out of sync, charging may stall at 0% until reset. [Elektroda, gradek83, post #18395325]
Do I need to pre‑balance and match cells when rebuilding this pack?
Yes. Match cells by capacity and voltage before assembly. Pre‑charge to the same level to prevent imbalance. The battery electronics controls charging and may require a reset after cell replacement. Some packs enforce cycle limits or protect settings with a password. As one tech said, “new cells must be properly prepared.” [Elektroda, gradek83, post #17427981]
Why does input current drop to zero when the screen shows charging?
A user saw 0.45 A input current until the display showed charging, then it dropped to zero. The LED remained lit but actual charging stopped. That behavior points to the control circuit refusing current after a fault flag. Inspect the pack and charge‑enable signals first. [Elektroda, bacaking, post #18393292]
Which Lenovo tablets show this 0% charging behavior?
Affected reports include TB‑X605F, YT3‑X50F, and YT3‑850L. One tablet also showed “battery temperature too low – charging aborted.” These symptoms implicate pack control or temperature sensing issues. Prioritize battery pack checks, temperature sensor wiring, and connector integrity before deeper board work. [Elektroda, bacaking, post #18393292]
What if a BMS reset didn’t fix it?
If BMS re‑seating fails, suspect a faulty or locked controller. One case showed the BMS output jumping to 4.3 V and dropping in a loop. That oscillation prevents stable charging. Replace the battery pack or swap in a known‑good BMS to confirm. [Elektroda, bacaking, post #18395193]
Can I talk to the battery gauge with TI EV2400?
Yes. Use TI EV2400 to interface with bq‑series gauges for data and configuration. As a member said, “have fun but it costs a bit.” This can expose cycle counts and protection flags. Some packs may block writes if password‑protected. [Elektroda, gradek83, post #17428125]
Where is the BMS on this battery and what does it look like?
It sits on a small PCB attached to the battery leads. Community photos show the board for YT3‑X50L and similar Lenovo packs. Trace the NTC, sense, and output lines from this board when diagnosing charging faults. [Elektroda, Mareeek_89, post #18395820]
What is the correct battery part number for YT3‑X50L?
Lenovo labels this pack L15D3K32 for the Yoga Tab 3 10, model YT3‑X50L. Use this code when searching for replacements or donor packs. Verify connector and dimensions before purchase. [Elektroda, martiv, post #17428026]
My port and battery test fine. Where should I look next?
Re‑check the charging socket for mechanical and electrical integrity under magnification. Confirm all pins and pads, then follow the charge path to the board circuitry. If the socket is suspect, replace it first. This simple step resolves many cases. [Elektroda, nutergsm, post #18617639]
What does “battery temperature too low – charging aborted” mean on Lenovo tablets?
The tablet halts charging when the temperature sense circuit reports out‑of‑range values. Inspect the NTC sensor on the pack and the wiring to the BMS PCB. A broken NTC line or connector can trigger this message and block charging. [Elektroda, bacaking, post #18393292]
Are new or used replacement batteries available?
Yes. Sellers list Yoga Tab 3 batteries under service parts categories for Lenovo Yoga models. Buying a replacement pack can be faster than rebuilding. Verify it matches L15D3K32 and arrives with the correct connector. [Elektroda, gradek83, post #17428125]
What if nothing works—should I return the device?
Yes. When practical fixes fail, returning the device can be the best choice. One case remained unresolved and was returned to the customer. Balance repair time, parts availability, and tablet value before proceeding. [Elektroda, martiv, post #18856750]
