LENOVO MIX 300 - Can you charge your tablet / laptop via USB?
mitusm 9714 9
Can the Lenovo Miix 300 be charged through its microUSB port, and what should I do if charging does not start?
Yes, the Miix 300 can charge through its microUSB port, but if charging does not start you may need to use a different power source or ensure the plug is fully seated. One reply says the microUSB port should work as the charger input and suggests trying a charger with about 5V and 4–5A if the current source is weak [#16695109] Another report says that after a full discharge, the tablet would only begin recovering with long charging from a low-current source such as a desktop USB port, and only after the battery reached about 20–30% did the original charger start working again [#16713741] A later reply also notes that the charger pin may need to be pressed in until the red charging indicator lights up [#16722291]
  • #1 16695010
    mitusm
    Help: 21
    Rate: 23
    Hello. I have a tablet / laptop lenvo mix 300. The tablet is charged with a 5V pin (2.3A charger). The tablet has a microusb, after connecting the charger to this connector (the same charger because it has a USB plug) charging does not start. There is an option to activate charging via micro usb or it is physically impossible ...
  • #2 16695109
    1 PAWEL
    Help: 674
    Rate: 1364
    mitusm wrote:
    the same charger because it has a usb plug
    Extra cable? to the charger may damaged.
    I think IdeaPad Miix 300? The micro USB port is working, it's connected to the charger - it should charge.
    Look for a slightly weak charger on 5V 4-5A.
  • #3 16697323
    mitusm
    Help: 21
    Rate: 23
    This is the original charger, the USB port as a hub works correctly. Unless there is no USB charging option.
  • #4 16712619
    Pawlos36
    This charger doesn't charge me either. In addition, the charger pin goes into the socket loosely and not completely and not like in other devices slightly with resistance and to the end. I don't know if I won't give this Lenovo to the store because my nerva is taking me. The battery is dead, the equipment is not used and I do not know how and how to charge it. Tragicomic situation.
  • #5 16713492
    mitusm
    Help: 21
    Rate: 23
    The charger and the original socket work normally, I was wondering if the emergency could be charged via USB.
  • #7 16713570
    mitusm
    Help: 21
    Rate: 23
    Other model.
  • #8 16713575
    1 PAWEL
    Help: 674
    Rate: 1364
    This is just an example of the problem.
  • #9 16713741
    Prot
    Help: 574
    Rate: 297
    mitusm wrote:
    I was wondering if it could be charged via USB in an emergency
    I encountered similar problems when charging another tablet - with "full" battery discharge the original charger did not charge at all :cry: no way. In my opinion, this was due to current limits - the capabilities of the charger itself and current limits for the USB connection.
    To charge (recover from full discharge :D ) this tablet I found only one solution - long charging with low current - I practically used the USB socket of a desktop computer :idea:
    After initial battery charging (20 -30%), the original charger "recovered" its efficiency :D
  • #10 16722291
    Pawlos36
    I'm fine now. Simply press the charger pin "on the chama" until the red charging indicator lights up.
    I was afraid that I would damage the charging socket and put it in half :)
The discussion revolves around the Lenovo Miix 300 tablet/laptop and its charging capabilities via micro USB. Users report issues with charging, particularly when using the original charger, which is a 5V 2.3A unit. Some users suggest that the micro USB port should function for charging, while others experience problems with the charger fitting loosely in the socket. A few users mention that charging from a USB port on a desktop computer can help recover a fully discharged battery. There are concerns about the charger’s current limits and the possibility of activating USB charging options. Overall, the consensus indicates that while the micro USB port is designed for charging, practical issues may prevent it from functioning correctly.
