Connecting 4-Wire Phone Cable to RJ-45 Pins: Updated Cisco CSS11000 Series Guide Link
patrycja00515 22200 4
  • Request for 4-wire phone cable RJ-45 pinout guidance
    #1 16237805
    patrycja00515
    I recently browsed the forum to find information on connecting a 4-wire phone cable to the appropriate pins in RJ-45. I have provided this link in the cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11000series/v6.10/ installation / guide / Pinouts.html however it does not work anymore because it's an old topic and link, and now I have the same problem. Anyone could help me how to connect this cable?
    Thank you in advance and best regards.
  • #2 16237893
    wtełek1
    Help: 19
    Rate: 55
    I use it:
  • #3 16237958
    patrycja00515
    Thank you for the answer, but I need a diagram of connecting four cables to the RJ45 pin with 8 pins. Is it supposed to be in turn 1,2,3,4 or otherwise?
    Greetings.
    jimasek
    Help: 3783
    Rate: 2681
    1,2,3,6 - if this pair is 1.2 and 3.6 in pairs. Of course, there is no standard or guarantee that it will work because it is a "guerilla" that will work with a little luck.
  • #5 16238078
    patrycja00515
    Thank you, I will try and talk about how it went :)
