MSI z170a Gaming pro Carbon board - Upgrade bios without cpu or with kabylake?
Shizo 5394 12
Can I update the BIOS on an MSI Z170A Gaming Pro Carbon without a CPU, or with a Kaby Lake CPU that is not yet supported?
No, you cannot flash the BIOS on this board without a CPU, and MSI Poland said you need an older Skylake 6th-gen processor to do the update if Kaby Lake support is not already present [#16241698] If you do not have access to such a CPU, the alternatives mentioned were to have the seller or a service update the BIOS for you, which was said to cost about 20–50 PLN [#16240414][#16240499] One thread reply also confirmed that you will not start the computer with an unsupported Kaby Lake CPU until the BIOS is updated [#16255206] The only exception is if the motherboard already shipped with a BIOS new enough for Kaby Lake, in which case the CPU may boot immediately; one user later reported his i5-7700K started because BIOS 1.6 was already installed from the factory [#16241698]
  • #1 16240390
    Shizo
    Rate: 77
    I have a new msi z170a gaming pro Carbon board, I ordered a new kabylake i5 7600k processor which requires newer bios available on the board's website. Is it possible to run the same setup without a processor or with one that is theoretically unsupported to upload a new bios? Is it Safe for the motherboard at all? ps. Please do not advise the obvious borrowing of an old skylake processor from someone because it's not so simple no one wants to do it free ...
  • #2 16240414
    Kasek21
    Help: 4981
    Rate: 3547
    No.
    Shizo wrote:
    Please do not advise on the obvious borrowing of an old skylake processor from someone because it's not so simple no one wants to do it free ...
    If you do not have a source, use the services of the website - 20-50 PLN.
  • #3 16240491
    Shizo
    Rate: 77
    Generally I know how it was that older boards but apparently some newer ones have the ability to run Bios even without a processor, I am still waiting for a response from the manufacturer of the board but I have to pick up the processor tomorrow and choose this problematic i5 7600k or maybe older i5 6600k
  • #4 16240499
    Kasek21
    Help: 4981
    Rate: 3547
    Shizo wrote:
    but apparently some newer have the ability to run Bios even without a processor
    No.
    Let them update the BIOS where you buy the disc.
  • #5 16240550
    Shizo
    Rate: 77
    I already have an album for some time, I will buy the rest. There is an option that I will buy a second older processor, once I start it, I will upload the bios and return the processor to the store. I wouldn't just scratched it, the CD will start without cooling on the cpu or will it turn off soon?
  • #6 16240556
    Kasek21
    Help: 4981
    Rate: 3547
    Shizo wrote:
    There is an option that I will buy a second older processor, once I start it, upload the bios
  • #7 16241698
    Shizo
    Rate: 77
    I got an answer from MSI Poland :
    "If the BIOS has not been updated to the latest KabyLake processor support, then you need to do this by connecting an older generation processor (SkyLake 6 series processor)
    Alternatively, you can advertise the product to the seller with the annotation "Request BIOS update for Kaby Lake processors"
    So everything is clear, only the older CPU can upload the BIOS.
    A small errata for today 02-02-2017:
    Kaby Lake i5-7700k on my board started smoothly, without bios update. It turned out that there was a BIOS 1.6 uploaded there, which was published on the MSI website on October 18, 2016 and added support: "Supported next generation new Intel CPU." - the CD was also bought in October 2016. Writing to MSI I gave them the serial number of the CD - did they not know what they recorded bios themselves?
    I have already uploaded a new bios 1.7 from 26-12-2016 which basically did not bring anything to the topic.
    Maybe some of you bought such a disc after 18-10-2017 and can comment on what version had the factory BIOS?
    I'm closing the topic
  • #8 16255198
    leshek1990
    Hey, I ordered the MSI B150 motherboard a few days ago and plan to buy an I5 7500 processor. I was just looking for information about this required BIOS update. I wonder if in my case it will also be possible to turn on the computer, since the only remaining option to upload the BIOS is to give the disc a warranty immediately after purchase or looking for a replacement prock on the 1151 base: /
  • #9 16255206
    Kasek21
    Help: 4981
    Rate: 3547
    You will not start the computer with this processor - you need to update the BIOS.
  • #10 16255226
    leshek1990
    Colleague Shizo started the computer from Kaby Lake on the disc, which theoretically needs updating, so there is a chance.
  • #11 16255234
    Kasek21
    Help: 4981
    Rate: 3547
    Chance, opportunity! You don't know what bios is uploaded!
    PS. Even if it does not start, uploading the bios in some store / service costs PLN 20-50.
  • #12 16255244
    leshek1990
    If I really buy an I5 7500 processor, I will let you know how the computer turned on for the first time :)
  • #13 16345492
    Shizo
    Rate: 77
    To sum up the topic, kaby lake on this disc will start and work without any problems provided that the bios supporting these processors has been won before. Without an older skylake lake processor, we won't win a bios.
The discussion revolves around the MSI Z170A Gaming Pro Carbon motherboard and the compatibility of the Kaby Lake i5 7600K processor, which requires a BIOS update for proper functionality. Users inquire whether it is possible to update the BIOS without an older Skylake processor or with an unsupported CPU. Responses indicate that an older Skylake processor is necessary to perform the BIOS update if the motherboard's BIOS has not been pre-updated to support Kaby Lake processors. Some users report success in booting Kaby Lake CPUs with certain BIOS versions already installed. The consensus is that without an older CPU, the BIOS cannot be updated, and users are advised to seek BIOS updates from retailers or service centers.
