MSI H110M PRO-VD - BIOS Update for i5_7400, GTX 1050Ti & GoodRam 2133MHz RAM Compatibility
dxh11 3678 1
  • Questions about BIOS 2B update and USB port
    #1 16439727
    dxh11
    I warmly welcome,
    just a shipment with the motherboard, processor, graphics card and RAM, the rest of the equipment is already there, but at the beginning there is a problem with updating the BIOS. I need your help in choosing the right version of this BIOS and installing it.
    The equipment is:
    MSI H110M PRO-VD
    i5 7400 3GHz LGA 1151
    ASUS GTX 1050Ti Expedition
    4GB of GoodRam 2133MHz RAM
    So yes, the first thing to do is to install a new Windows 10, can I go straight to the BIOS?
    Moving on, from the MSI website https://pl.msi.com/Motherboard/H110M-PRO-VD.html#hero-overview in the support tab I download the latest BIOS version, i.e. 2017-02-10 ver. 2B, then unpack the downloaded file and transfer it to the pendrive, plug it in and restart it.
    I also have a question, is it important from which USB from the MSI H110M motherboard I will boot the pendrive? Somewhere I saw that some boards had USB ports labeled with the name BIOS Flashback. For me, of course, it is not, so I bet that I can boot it from any port except USB 3.0. I will return to the next part of the topic, please indicate / correct the errors that I made in this BIOS update process.
  • #2 16441530
    DriverMSG
    Help: 3984
    Rate: 4883
    Irrelevant.
    dxh11 wrote:
    Is it important from which USB from the MSI H110M motherboard I will boot the USB flash drive?
    Yes. Preferably with USB 2.0.
