Best Affordable Motherboard Options for i5 8600k, MSI GTX Nvidia 1050ti, and Corsair RAM
marvetst 2946 2
  • #1 16875447
    marvetst
    Hello, due to the fact that I bought a new i5 8600k processor, my motherboard is for sale exactly MSI B250M. So I need a new motherboard not too expensive up to 150 euros max.
    My equipment
    Processor: i5 8600k 3.6 GHZ Unlocked
    Graphics card: MSI GTX Nvidia 1050ti 4 GB (I always crank it up to 200mhz core with 500 memory)
    RAM: 2x 8GB Corsair 2400 MHZ (CMK16GX4M2A240C14R)
    Power supply: Chieftec 500W (some crap will also fail)
    Drive: SSD Adata SU800
    I am asking for suggestions and thank you in advance :-)
    Added after 11 [minutes]:
    https://www.megekko.nl/product/2026/209524/Intel-Socket-1151/MSI-Z370-KRAIT-GAMING
    will such a motherboard be suitable?
    Added after 34 [minutes]:
    https://www.megekko.nl/product/2026/209523/Intel-Socket-1151/MSI-Z370-GAMING-PRO-CARBON - I found that I will buy this motherboard I don't know if RAM memory will work but it should have a string of letters and numbers is not the same but in B250m it was also not and RAMs work.
  • #2 16875575
    Piterixos
    Help: 38
    Rate: 56
    All currently available CDs for Coffe Lake are based on the Z370 chipset and are intended for high-end PCs, too, and basically anyone can do it.
    Gaming Pro Carbon is a solid MSI proposition, so if you can afford it, go ahead, it has everything you need.
    And of course remember that with this prock you should get a more decent graphics card.
  • #3 16875588
    marvetst
    Thank you for your reply, Pro Carbon ordered. :-)
