Recommended Motherboard for Intel Core i5-3570, MSI GeForce GTX 750Ti, HyperX Savage 2x4GB RAM
majlo804 5592 13
What motherboard should I buy for an Intel Core i5-3570, MSI GeForce GTX 750Ti, and HyperX Savage 2x4GB DDR3 RAM?
You should buy an LGA1155 motherboard; for an Ivy Bridge i5-3570, a 7-series chipset board such as B75, Z77, H77, Q77 or Q75 is the safest choice, and on 6-series boards a BIOS update may be required for CPU support [#16435373] If you want to avoid compatibility issues, just pick a board for LGA1155 instead of looking for a new platform [#16432085][#16432092] The forum also notes that boards for this processor still exist, including on the used market, and one reply specifically suggests the ASUS board that was recommended earlier [#16435347][#16435410]
  • Request for compatible replacement motherboard after short circuit
    #1 16231427
    majlo804
    Hello, what motherboard do you recommend for the processor
    - Intel(R) Core (TM) i5-3570 Processor
    - MSI GeForce GTX 750Ti GAMING 2GB GDDR5 (128 bit) HDMI, DVI, D-Sub (N750Ti TF 2GD5 / OC)
    - HyperX Savage 2x4GB 1866MHz DDR3 CL9 (HX318C9SRK2 / 8)
    - XFX TS 550W 120mm 80+ Bronze Power Supply (P1-550S-XXB9)
    I will add that previously there was ASRock B75 Pro3-M but I damaged it by accident and there is a short circuit,
    The computer turns on when I press POWER but after 5 seconds it turns off and it turns on after a while and so on and on.
  • #2 16231435
    sylweksylwina
    Help: 1882
    Rate: 2355
    What budget? Are used records also available? Do you care about integrated graphics? Will you change the processor to one with an unlocked multiplier in the future and overclock it?
  • #3 16231439
    majlo804
    yes, up to PLN 350 not used, it depends on the graphics, because if it burns or something, it is worth having an alternative. As for the processor, this one is enough, it is the same as the 4470K only with unlocked :D
  • #4 16231446
    sylweksylwina
    Help: 1882
    Rate: 2355
    Micro ATX case or normal?
  • #5 16231448
    majlo804
    I plan to change because I get some bad vibrations and I make strange sounds and the fans are a pity to talk after 2 years they go as if you were to pour sand I do not recommend :(
    - Brutus M25 Pure Black (BT-M25)
    ATX because m-ATX is too small and there's nowhere to put your hand.
  • #6 16232085
    marconii2002
    Help: 5
    Rate: 54
    Please forget about the new motherboard for this processor because they are not produced.
  • #8 16435332
    majlo804
    the best solution is to replace the processor.
    Thanks
  • #9 16435347
    sylweksylwina
    Help: 1882
    Rate: 2355
    After all, there are boards for this processor without a problem.
  • #10 16435359
    majlo804
    on the old chipset I had b75 pro-3m
  • #11 16435373
    sylweksylwina
    Help: 1882
    Rate: 2355
    The chipset may be different and you give the board model anyway ...
    Buy a CD for LGA1155 and that's it. Alternatively, a BIOS update may be required on 6 series chipset boards to support ivy Bridge. On motherboards with the 7 series chipset, i.e. for example: Z77, Q77, H77, Q75, B75, the update will not be required.
  • #12 16435410
    Kasek21
    Help: 4981
    Rate: 3547
    Take the ASUS I recommended.
  • #14 16435639
    sylweksylwina
    Help: 1882
    Rate: 2355
    Why would it not work?
The discussion revolves around finding a suitable motherboard for the Intel Core i5-3570 processor, paired with an MSI GeForce GTX 750Ti graphics card and HyperX Savage 2x4GB RAM. The user previously used an ASRock B75 Pro3-M motherboard, which was damaged due to a short circuit. Participants in the discussion inquire about the user's budget (PLN 350), preferences for integrated graphics, and whether they plan to upgrade the processor in the future. Suggestions include looking for motherboards compatible with the LGA1155 socket, specifically those with 7 series chipsets (Z77, Q77, H77, Q75, B75) that do not require a BIOS update for Ivy Bridge support. Some responses suggest that new motherboards for this processor are no longer produced, while others assert that options are still available.
