Peugeot Boxer III 2016 - What program to delete service inspections?
Mariuszguzicki 19737 9
How can I reset/delete the service inspection and oil lamp on a Peugeot Boxer III 2016 with DPF, and which diagnostic program works for it?
Use Diagbox for the reset; ELM 1.4 was reported as unsuitable for the Boxer, while Autocom/Delphi 2015 and KTS Bosch were also said to work for deleting the inspection [#16241198][#16241212][#16241174][#16811435] One reply specifically stated that Diagbox should handle it “100%” [#16241198] As an alternative, a manual reset procedure was described: switch the ignition on, press the accelerator pedal to the floor 3 times within about 15–20 seconds, then turn the ignition off and wait for the service message to appear [#16583704] Another user noted that the simple “3 presses” version did not work for them, so the exact procedure may vary or require the correct timing [#16811136]
  • #1 16241153
    Mariuszguzicki
    Hello, as in the subject I have a problem with resetting the oil lamp the car is from DPF I read from ELM 1.4 is able to do it only I do not know if it will not need FES adapters ?? Possibly, another program may autocom 2015 ??
  • #2 16241174
    MarcinS70R
    Help: 52
    Rate: 290
    Autcom / Delphi in the 2015 version certainly gains.
  • #3 16241185
    Mariuszguzicki
    Maybe I can find the 2015 version I will check and let me know but ELM wonders.
  • #4 16241198
    szymitsu21
    Help: 343
    Rate: 1300
    I personally have not tested but ELM is probably rather hard.
    Diagbox at 100%.
  • #5 16241212
    MarcinS70R
    Help: 52
    Rate: 290
    ELM can not handle Boxer.
    In the Fiat Ducato, maybe even like MultiEcuScanie.
  • #6 16241285
    Mariuszguzicki
    Diagbox which version will support Euro5 with DPF?
  • #7 16583704
    maciej166
    Rate: 9
    Witam?
    To delete the inspection in this car, all you need is a human brain key, efficiency in the legs with the possibility of logical coordination and right hand to operate the key 15-20 sec inspection deleted
    blinking oil filter Itd ....
    https://m.youtube.com/watch?v=jJo5e71kBPs
    After finishing, wait with the ignition off until a message about the service procedure is displayed.
    Turn off the ignition and take off the gas and brake legs.
  • #8 16811136
    marcin910w
    Rate: 23
    Welcome.
    The video only says that, we turn on the ignition, press the gas pedal 3 times to the stop, turn off the ignition, start the car. But unfortunately this operation does not work.
    Could anyone describe it exactly how to do it? Thank you in advance
  • #9 16811435
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    KTS Bosch will definitely withdraw.
  • #10 16812456
    jarek225
    Help: 64
    Rate: 221
    Try here: link
    It may help you.
The discussion revolves around resetting the service inspection light on a 2016 Peugeot Boxer III, with users exploring various software options. Autocom/Delphi 2015 is suggested as a viable solution, while ELM 1.4 is deemed inadequate for this model. Diagbox is recommended as a reliable tool for resetting the oil lamp, although specific version compatibility for Euro5 with DPF is questioned. A user shares a manual method involving the ignition and gas pedal sequence, but others report it may not work effectively. KTS Bosch is also mentioned as a potential tool for this task.
