Monitor Enters Energy Saving Mode with MSI Radeon R9 270X: DisplayPort, VGA, HDMI & Resolutions
WyWy 8517 19
Why does my monitor on a DisplayPort-to-VGA adapter enter power save mode at higher resolutions, and what should I do to make it work normally?
The adapter/converter is the most likely problem, not the monitor or cable, because the same monitor works normally on another input and the issue persists after swapping cables and reinstalling the graphics driver [#16243178] [#16243187] [#16243346] [#16244383] Set the monitor on the UNITEK converter to its native 1920 × 1080 at 60 Hz if that is the supported mode, but if it still drops to power save above 1024 × 768, the converter is behaving incorrectly or is incompatible [#16243272] [#16243286] Since the problem started suddenly after working before, the best next step is to return/exchange the adapter under warranty [#16244388] [#16244394] An HDMI-to-VGA solution may work only with a proper active converter, and even then some users report problems [#16244388]
  • DisplayPort-to-VGA adapter fails at higher resolutions
    #1 16242976
    WyWy
    Hello one of my monitors is problematic I have two monitors connected via adapters this problematic is connected via VGA on displayport when turning on the computer both monitors work without any problems but after starting the computer the monitor connected via displayport entered into powersave mode I clicked something and changed the resolution to 1024 x 768 and the monitor works normally, displays the image and at lower resolutions also but at higher resolutions it does not go into economy mode and now my question what should I do? my graphics card is msi radeon r9 270x I also bought an HDMI adapter but then the computer does not even detect the monitor. I will add that the monitor works without any problem at any resolution on a different DVI input on the one on which I have a second monitor so this is not a problem with the cable or the monitor rather not.
  • #2 16242988
    Kasek21
    Help: 4981
    Rate: 3548
    What are these adapters?
    What are these monitors?
  • #3 16242996
    WyWy
    One is vga for displayport and one is dvi for vga
    Added after 52 [seconds]:
    Monitors random LG and samsung the one that causes problems is LG FlatronE2242 and the other samsung S22D300
  • #4 16243016
    Kasek21
    Help: 4981
    Rate: 3548
    That much is known :)
  • Clarifying whether specific DisplayPort and HDMI adapters are involved
    #5 16243028
    WyWy
    is it about models? like this http://www.komputronik.pl/product/106302/Ak accessories/Kable_i_adaptery/Adapter_DisplayPort_VGA_F_Unitek.html this is the displayport and the other one is http://www.sferis.pl/adapter-video-savio-cl- 21-hdmi-dvi-fm-cl-21-p414196 something like that I'm not sure now but earlier everything worked at night I turned off the computer in the morning I turn it on and it stopped working
  • Clarifying monitor inputs and previous working configuration
    #6 16243042
    Kasek21
    Help: 4981
    Rate: 3548
    From what you can read, both monitor models have only a D-Sub input (unless this Samsung model is with some extension?).
    You have one monitor connected to the DVI-I connector through the adapter and it works OK? Yes?
    Want to connect a second monitor that only has D-Sub? Yes?
    WyWy wrote:
    but before everything worked at night I turned off the computer in the morning I turned on and stopped working
    What did it work on?
  • #7 16243047
    WyWy
    Well, as it is now it works, sorry if something is spinning or I present vaguely, I do not know, but these monitors have DSUB input and I connect these adapters to the computer and connect the monitors.
  • #8 16243178
    310artur
    Help: 980
    Rate: 670
    Swap monitors (place the cables on the monitor side). We'll see if the problem has the monitor or the unit converter.
  • #9 16243187
    WyWy
    changing cables makes the second monitor have the same problems as the previous one
  • #10 16243272
    310artur
    Help: 980
    Rate: 670
    I understand that you have the flatron in the E2242S version - the E2242T version has DVI on the back except VGA.
    Set the resolution 1920 x 1080 @ 60 Hz for the monitor connected to UNITEK.
    Unitek who is not an adapter and an analog to digital converter has a problem. And he has to please him.
  • #11 16243286
    WyWy
    When I change the resolution, the monitor enters the power save mode :(
    Added after 32 [seconds]:
    Works only on 102 4 x 786 and below
  • #12 16243295
    Kasek21
    Help: 4981
    Rate: 3548
    Did it work normally before? Ie. on the native resolution of this monitor?
  • #13 16243310
    WyWy
    That's how everything worked normally yesterday at native resolution this morning I turned on the computer and this problem appeared.
  • #15 16243347
    Kasek21
    Help: 4981
    Rate: 3548
    Refreshing is the same as before?
    Maybe there was an adapter.
  • #16 16243369
    WyWy
    Yes, refreshing is the same I will try with this driver and the adapter does not know if it could fall because the monitor works, but with a lower resolution
  • #17 16244383
    WyWy
    After reinstalling the drivers, the same problem appears as I uninstalled them, two monitors showed the same image and after installing one works and the one on the displayport again only 1024 x 786 resolution or smaller and on larger power save mode
  • #18 16244388
    Kasek21
    Help: 4981
    Rate: 3548
    If it's under warranty, give it back.
    A lot of people use the Converter Converter from HDMI to VGA cable DSUB FV Wwa (6598037737) and usually works correctly - they write usually because a few people had problems.
  • #19 16244391
    WyWy
    I just bought one and when I connect a monitor to it, the computer doesn't even detect it :(
  • #20 16244394
    Kasek21
    Help: 4981
    Rate: 3548
    It's like I wrote, give that one back for warranty, let them exchange it if everything worked before.
The discussion revolves around a user experiencing issues with a monitor connected via a DisplayPort to VGA adapter, specifically an LG Flatron E2242, while using an MSI Radeon R9 270X graphics card. The monitor enters power-saving mode when set to higher resolutions, functioning only at 1024 x 768 or lower. The user has attempted various resolutions and has also purchased an HDMI adapter, which the computer fails to detect. Responses suggest checking the adapters, swapping cables, and reinstalling graphics drivers. The user reports that after driver reinstallation, the problem persists, with both monitors displaying the same image at times. Recommendations include returning the HDMI adapter under warranty due to detection issues.
