PC Monitor Out of Range - LG Flatron W1943S, D-Sub to DVI Adapter, AMD Radeon HD 5700
Bluemen9812 13551 7
  • #1 16529543
    Bluemen9812
    Hello! I bought a used computer. After connecting my old monitor (LG flatron w1943s) via the d-sub adapter -> dvi, the message "out of range 55.9.9 khz KHz / 60 h Hz. "How to fix it? Gpu amd Radeon hd 5700.
  • #2 16529561
    kindlar
    Help: 919
    Rate: 1622
    The monitor does not support the refresh rate as it is currently set. Start the system's emergency mode remove the monitor and graphics card then restart and set up your monitor.
  • #3 16529597
    Robert B
    Help: 2027
    Rate: 1412
    Also install the monitor driver.
    • LG1.zip (7.72 KB) You must be logged in to download this attachment.
  • #4 16529650
    Bluemen9812
    I did it, I started again showed me the desktop after a while the sound of connecting the device and again the message about the scope of work: /
  • #5 16529678
    Robert B
    Help: 2027
    Rate: 1412
    Have you also deleted driver files? And maybe we'll finally find out what system?
  • #6 16529695
    Bluemen9812
    Windows 8.1
    Device manager> monitor / graphics card> uninstall. What if I do this?
  • #8 16722302
    Bluemen9812
    new monitor purchased ;)
The user encountered an "out of range" error message when connecting an LG Flatron W1943S monitor to a computer using a D-Sub to DVI adapter with an AMD Radeon HD 5700 GPU. Responses suggested that the issue was likely due to an unsupported refresh rate. Recommendations included starting the system in emergency mode, uninstalling the monitor and graphics card drivers, and installing the correct monitor driver. The user later confirmed they were using Windows 8.1 and considered uninstalling drivers via Device Manager. A suggestion was made to use the AMD Clean Uninstall Utility for a thorough driver removal. Ultimately, the user decided to purchase a new monitor.
