Volkswagen 1.9 TDI - Booming / roaring while driving in 4th and 5th gear
moop 26148 19
Why does my Volkswagen 1.9 TDI roar or buzz only at a steady speed in 4th and 5th gear, and what should I check?
The thread points to a wheel/rim fitment issue rather than the gearbox or clutch, because the humming changed when different wheels were fitted [#17397315] [#17420196] Check wheel alignment, wheel bearings, tire condition, and especially the rims’ offset/width and any spacers, since the posted 15" steel wheels (ET42, 6.0") were said to lightly rub the brake calipers and the advice was to try original-style rims without spacers [#17392299] [#17420795] The gearbox oil was found slightly below minimum and refilled, but that did not remove the noise, which also makes the gearbox less likely [#17388823] [#17420196]
  • #1 17323046
    moop
    Hi!
    I am asking you for advice, which may be the reason for the buzzing / roaring while driving a Volkswagen 1.9 tdi 90 HP (manual transmission, without a dual-mass wheel) in 4th and 5th gear.
    Noise only occurs when driving at a constant speed between 70 and 100 km / h, as soon as I lightly press the acceleration (maintaining the speed).
    I would add that sometimes the noise is high and you can feel the slight vibration of the car - as if something was rubbing. However, if it was friction, it would probably occur all the time?
    The thing is, pressing the clutch makes the roaring stop. When idle, it also stops. Similarly during acceleration and engine braking.
    Unfortunately, the cause could not be found at the diagnostic station ... That's why I am asking you for ideas, what I could check.
  • #2 17323670
    decybel91
    Help: 1021
    Rate: 4210
    It's hard to say - it is not known what model, because vw 1.9tdi produce over 20 years.
  • #3 17324374
    Staszek49
    Help: 228
    Rate: 1139
    Dude, no offense, but what technique do you drive this car. Just for the record, it is a tdi engine, so it must have and the right speed. Driving at a speed of 70 km / h in 5th gear is rather a "homicide" for this engine. This engine starts working properly from min. 2000 revolutions per minute.
    I drove a Passat with such an engine before. In my opinion - the sound effects described by you can be caused by driving at low engine revs.
  • #4 17324429
    iron64
    Help: 648
    Rate: 312
    It is quite possible that the author uses PSJ, although at 70km / h in 4th gear it should be around 2000rpm. Well, unless the clutch is fed up then it happens differently.
  • #5 17324475
    SKM 1964
    Help: 150
    Rate: 660
    The bearing supporting the clutch shaft sits securely and does not center the clutch disc. All you need is a slight shift after clutching the i9, the engine will vibrate.
  • #6 17324505
    moop
    Let me explain.
    The car has a 1Z engine from 1995.
    The fourth gear is 70-90 km / h, the fifth is over 90 km / h.
    The sound is unlikely to sound like a stewed engine at low speed. Rather, it's friction - like bearings ..?
    Indeed, I do not always drive at a constant speed above 2000 rpm, but I never choke the engine at low speed and try not to drive below 1700. I don't have a tachometer, but I once rode with a connected interface to check how the car behaves at different speeds.
    I would add that for a year everything was fine and the specific noise has been accompanying driving for some time. I haven't changed my driving style.
    I'm going to check the oil in the chest, but only after I deal with the cork. Although it seems to me that a damaged box should make noise all the time, and not only when gently pressing the accelerator pedal in the strict speed range ...
    Joints replaced.
    I changed the wheels, but if something rubbed, it should probably be heard all the time.
  • #7 17388823
    moop
    Only yesterday I was able to take care of the car. I changed the oil in the gearbox - the level was slightly below the minimum and now the gears are going quite well. Unfortunately, the humming I described still occurs.
    Does a damaged clutch shaft bearing bear such symptoms? Shouldn't it make noise all the time?
  • #8 17391689
    kakibara
    Help: 202
    Rate: 1278
    Accelerate the car to 100km / h, loose it - press the clutch - release - any changes? Re-apply with gears 4 and 5.
    If you rode with no oil - below the mine, maybe the crate has fallen.
  • #9 17392299
    LENIWIEC_PL
    Help: 119
    Rate: 320
    I would check the alignment of the front and rear wheels. It is an old car so something could have gently broken apart. As you wrote, the buzzing occurs above 70km / h so this could be it.
    It would be worth checking again:
    wheel bearings
    gearbox condition (oil quantity, mode status)
    tires are not serrated
    the clutch release bearing - it may not have slack, but it will be dry inside and it will also humming
  • #10 17393413
    moop
    Hi
    Today I will test the car on the road by the method kakibara and I will let you know.
    I will definitely check the wheel alignment, although the humming occurs not always, but only when gently pressing the accelerator pedal (when I maintain a constant speed). When slowing down and accelerating (whether on the run or at ease) everything is fine.
    Wheel bearings are normal. The tires have one season and only 2-3 thousand km of mileage.
    The thrust bearing actually has no clearance, but I don't know if it is lubricated properly; to check it you need to dismantle the clutch?
    The oil level in the gearbox is now normal. How does it look inside - I have no idea ...
  • #11 17394765
    LENIWIEC_PL
    Help: 119
    Rate: 320
    The thrust bearing usually does not have any lubrication from the engine, etc. it is simply factory lubricated with the appropriate grease and when it dries, it loses its lubricating properties and, as a result, the bearing starts to roar, squeak or simply fall apart. We do not grease bearings and replace them.
    Now normal and before? What was it riding on? When was the oil changed in it? It would be best to swap it for another crate and check it but it involves expense.
    Do all rims have the same width and offset? Are they all equal?
  • #12 17397315
    moop
    I moved forward slightly to solve the problem.
    I tested the car on the route yesterday, but earlier I changed two front wheels to another one - borrowed; admittedly aluminum and wider (protruding beyond the outline of the car) and with winter tires, but with the same diameter.
    Interestingly - in 4th gear the humming sound completely stopped; I checked in the 70-110 km / h range.
    In the 5th gear, it hums much quieter and only after exceeding about 110-120 km / h. Below - silence.
    Therefore, I eliminate - probably rightly - problems with the gearbox and clutch.
    Was it a matter of convergence?
    The steel wheels and tires on which the buzzing occurs are new and balanced. They only have a smaller ET, but they don't seem to rub anything.
  • #13 17398457
    LENIWIEC_PL
    Help: 119
    Rate: 320
    I wrote to you before that you could check it. Did you check?
  • #14 17399291
    moop
    Of course, I'm going to check this coincidence.
    I started with the simplest (no-cost) things.
    I will definitely inform you about the results of the study.
  • #15 17400199
    SKM 1964
    Help: 150
    Rate: 660
    At home in the car I replaced all the bearings in the wheel hubs. First, he began to howl at the back so that it seemed the least to me. After the exchange came the front. I exchanged both together. And finally there is peace. I tasted a bit but it was worth it. :D
  • #16 17401158
    moop
    It's just that the bearings make noise all the time. For me, roaring occurs only in strictly defined situations ... For now I will focus on convergence.
  • #17 17403080
    SKM 1964
    Help: 150
    Rate: 660
    It's not all the time. They were starting to make noise from around 40 km / h. :|
  • #18 17420196
    moop
    Hello after a break.
    Convergence checked - it's okay.
    Bearings - also fine.
    Tires changed to different and the wheels balanced again - roaring unchanged.
    Evidently something is wrong with the rims ...
    The assumed 15 "steel wheels have an offset (ET) of 42 and a width of 6.0".
    As they are mounted directly on the hub, they gently rub against the brake calipers, 5mm thick aluminum spacers are added.
    I think to try to put other steel rims - no distances.
    Will ET 36 and width 5.50 "be OK? Will there not be any changes in terms of distance from the clamp?
    If I do not choose other rims, I will still have to try other distances (although these are even and undamaged) and if it does not help, then I must accept the noise during the ride.
  • #19 17420795
    LENIWIEC_PL
    Help: 119
    Rate: 320
    ET detachment determines the horizontal distance between the rim assembly plane to the hub and the plane of symmetry. So to put it simply, the larger the ET, the deeper the wheel hides in the wheel arch. And the smaller the ET, the more it protrudes from the wheel arch. So in your case less weaning will be better.
    As for distances, centering measures and similar miracles, when working on vulcanization sometimes it happened that through these distances the rim unevenly settled on the hub which caused a roaring or vibration on the steering wheel. Personally, in my opinion it would be better to mount original rims without any distances.
    Show the tread of the tires you have fitted.
  • #20 17421742
    moop
    As for ET, I understand that with the same width and smaller ET, the wheel rim will enter the wheel arch less and it will slide out more, but I doubt the 0.5 "smaller (5.5" instead of 6 ") and smaller ET ( 36 instead of 42) - I'm just afraid that the distance from the caliper will not change.
    The problem is that other 15 "rims are difficult to access, and the original ones are 13" and I would have to replace a set of new tires with new rims (several thousand km) - and that means a lot of costs ...
    The original are:
    Diameter: 13 "
    Width: 5,50J "
    Embedding ET: 38.00
    I have these:
    Diameter: 15 "
    Width: 6,00J "
    Embedding ET: 42.00
    And I have available such (then I replace the rims only - front without distances):
    Diameter: 15 "
    Width: 5,50J "
    Settling ET: 36.00
    Maybe it is a problem of these distances - it is very difficult to say.
    Maybe I'll just try to replace them, maybe they have some invisible flaw. This is definitely a lower cost than replacing a set of wheels.
    The tire tread does not bear any signs of wear - I have driven a possible 2 thousand km on them.
✨ The discussion revolves around a Volkswagen 1.9 TDI experiencing a booming or roaring noise while driving in 4th and 5th gear at constant speeds between 70 and 100 km/h. The noise ceases when the clutch is pressed and does not occur during acceleration or engine braking. Various potential causes are explored, including low engine RPMs, clutch shaft bearing issues, and wheel alignment. The author has checked the gearbox oil level, replaced wheel bearings, and tested different wheels, which led to a reduction in noise. The conversation highlights the importance of proper wheel alignment, bearing lubrication, and the impact of wheel offset on vehicle performance.
TL;DR: For VW 1.9 TDI (1Z) owners chasing 4th/5th‑gear booming, start by avoiding lugging; "engine starts working properly from min. 2000 rpm" (2000 rpm). Then check wheels, spacers, alignment, and run quick clutch/wheel‑swap tests. [Elektroda, Staszek49, post #17324374]
Why it matters: It helps you isolate load‑dependent humming fast and avoid unnecessary gearbox work.
What RPM should I use to avoid lugging my 1.9 TDI?
Keep the engine above 2000 rpm to avoid lugging. A forum expert noted, "this engine starts working properly from min. 2000 revolutions per minute." Avoid using 5th at 70 km/h. Use lower gears to hold rpm in the efficient band. [Elektroda, Staszek49, post #17324374]
How do I run a quick road test to confirm the noise is drivetrain‑load related?
Use a simple clutch‑in test at speed to isolate load dependency.
  1. Accelerate to 100 km/h on a safe, straight road.
  2. Shift to neutral, press the clutch, then release; listen for changes.
  3. Repeat in 4th and 5th; compare the results. He advised, "Re‑apply with gears 4 and 5." [Elektroda, kakibara, post #17391689]
If pressing the clutch makes the noise stop, what does that suggest?
Noise that vanishes with a clutch press indicates load‑dependent drivetrain sources. The author noted it also disappears at idle and during acceleration or engine braking. That points away from always‑on rubbing and toward items engaged only under light throttle. [Elektroda, moop, post #17323046]
Could low gearbox oil be the cause of the humming?
Low gearbox oil can affect shifting feel but may not cause this hum. The level was slightly below minimum; fresh oil improved shifting, yet the humming persisted. Confirm level, then continue with wheel and fitment checks. [Elektroda, moop, post #17388823]
What wheel and tire checks should I do first?
Check front and rear wheel alignment. Inspect wheel bearings for play or noise. Confirm gearbox oil quantity and mode status. Inspect tires for serration. Evaluate the clutch release bearing for dryness or wear. [Elektroda, LENIWIEC_PL, post #17392299]
Can wheel spacers cause humming or vibration even when wheels are balanced?
Yes. Spacers can leave the rim unevenly seated on the hub, creating roaring or steering vibration. One tech noted such cases during tire work. "Better to mount original rims without any distances." If possible, eliminate spacers in testing. [Elektroda, LENIWIEC_PL, post #17420795]
What did swapping to different wheels reveal in this case?
Swapping to different 15″ wheels stopped the 4th‑gear hum across 70–110 km/h. In 5th, the hum appeared only above about 110–120 km/h. That implicates wheels, ET, or spacers rather than internal gearbox or clutch parts. [Elektroda, moop, post #17397315]
Could wheel hub bearings still be at fault if the noise isn’t constant?
Yes. One owner heard bearing howl begin around 40 km/h, then replaced them. Bearings can drone at specific speeds, not constantly. Test under load and replace in pairs if needed. [Elektroda, SKM 1964, post #17403080]
Is the clutch release (thrust) bearing lubricated or serviceable?
The clutch release bearing is factory‑greased and not serviceable. When grease dries, it can roar, squeak, or fail. Do not re‑grease it; replace it. "We do not grease bearings and replace them." [Elektroda, LENIWIEC_PL, post #17394765]
How does wheel offset (ET) affect fitment and potential noise sources?
Offset (ET) sets how deep the wheel sits relative to the hub. Larger ET hides the wheel deeper; smaller ET pushes it outward. "Less ET will be better" for clearance in this case. It may let you remove spacers that add noise risk. [Elektroda, LENIWIEC_PL, post #17420795]
My 15″ 6J ET42 rims needed 5 mm spacers to clear the calipers—what should I try next?
Your 15″ 6.00J ET42 steels needed 5 mm spacers to clear calipers. Trying 15″ 5.50J ET36 fronts without spacers is a sound next step. If clearance fails, test other spacer sets and inspect their flatness. [Elektroda, moop, post #17420196]
Is it safe to keep driving while I diagnose this humming?
Be cautious. Running with gearbox oil below minimum risks internal damage. A member warned that after such use "maybe the crate has fallen". Correct fluids first, then limit driving until tests conclude. [Elektroda, kakibara, post #17391689]
