Free DVB-T USB Tuner: Using DVB-S Signal Meter on DVB-T & Windows XP Compatible Meter Options
ShakeAll 7257 18
Can I use a DVB-S signal meter to measure DVB-T, and is there a free Windows XP meter that shows more than signal strength and quality?
No, a DVB-S meter cannot be used to measure DVB-T, and the thread says there is no reasonable free Windows XP program that shows more than signal strength and quality [#16248340] If you need more detailed measurements such as dBuV, BER, signal/noise, and spectrum, users say you need a dedicated meter, roughly PLN 400–450, because cheaper options are not considered usable [#16249523] One reply adds that a USB DVB-T receiver can act as a meter only if its chipset/software exposes diagnostic data, but that requires chipset-specific support [#16250680] For the specific tuner mentioned, the advice was to look up the demodulator/chipset and search for Linux software that can report level, MER, and BER [#16250680][#16250906] Also, there is no program that will show only the signal strength of a given MUX without decoding a channel first [#16250674]
  • #1 16247825
    ShakeAll
    Help: 29
    Rate: 135
    While recently cleaning up computer junk, I found a DVB-T USB tuner. It seems like no big deal, but considering that I haven't been watching TV for 11 years, I felt like playing a bit, just for sport, by no means the need to watch commercials and propaganda.
    I will probably pick out a bi-quad antenna, but I could use some DVB-T signal meter and here two questions arise:
    - I have a DVB-S signal meter somewhere in my head, can it be used to measure DVB-T?
    - is there any reasonable free meter under WInXP that will show something more than signal strength and quality?
    Greetings...
    ShakeAll
  • #2 16248340
  • #3 16248895
    ShakeAll
    Help: 29
    Rate: 135
    mihal2002 wrote:
    Oh, how much was this thing worth?
    Probably PLN 30, used exactly once and it has been lying in a box for several years.
  • #4 16249199
  • #5 16249523
    Adi01
    Level 19  
    Help: 24
    Rate: 32
    ShakeAll wrote:
    meter ........... which will show something more than signal strength and quality
    With basic information: dBuV, BER, signal / noise, spectrum is about PLN 400-450. Cheaper you won't find anything usable.
  • #6 16250047
    lord232!
    Help: 107
    Rate: 178
    Added after 39 [seconds]:
    He will find. On a known auction site. For around PLN 250 satlink ws-6906. I use it myself and it's OK.
  • #7 16250098
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    For DVB-T ??
  • #8 16250220
    lord232!
    Help: 107
    Rate: 178
    And I also got a blow to DVB-S. I speeded up a little bit.
  • #9 16250548
    ShakeAll
    Help: 29
    Rate: 135
    It's now from another barrel ...
    In the DVB-T tuner support programs, signal strength and quality are only shown after decoding a specific channel.
    Is there any program that shows only the signal strength of a given MUX?
  • #10 16250674
  • #11 16250680
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    This USB receiver can be such a meter - most installation meters are simply consumer receivers with added software that shows the parameters (in addition, they are pre-calibrated but their accuracy is usually within a few dB).
    It would be good to check what demodulator is used in this receiver and look for access to the diagnostic part.
  • #14 16251996
    ShakeAll
    Help: 29
    Rate: 135
    Thanks, I'll search.
    I still have a question on what frequency to make a bi-quad to receive MUXs 1,2,3 from the transmitter Częstochowa Wśmieyca or possibly Katowice Kostowy?
  • #15 16253328
    4emtec
    Rate: 12
    DVB-T finder
    Search engine for the nearest Polish DVB-T and T-DAB transmitters. Searches for transmitters based on GPS or a given address. Additionally, it displays a map and a graph of the height dependence on the distance between the transmitting antenna and receiving antenna.
    The program operates in Poland, Germany, the Czech Republic and Slovakia.
  • #16 16253446
    borax
    Adi01 wrote:
    Gauge
    What would a friend recommend in this class?
  • #17 16254129
    czarny_alibaba
    Help: 5
    Rate: 151
    Digitsat meter PCM-1210 DVB-T / T2, DVB-S / S2, DVB-C for industry :idea:
  • #18 16256365
    Adi01
    Level 19  
    Help: 24
    Rate: 32
    The PCM-1210 is a Combo meter, if only DVBT / T2 is needed, the TM-600 (Digitsat) is cheaper.
  • Choosing bi-quad frequency for Częstochowa or Katowice MUXes
    #19 16330234
    M.Mikolajski
    Help: 13
    Rate: 22
    the appropriate biqad thread can be found on the Emitel forum is quite detailed with formulas for the right frequencies - I myself use this for the frequency from the transmitter in my area - a few pieces of my work work in different parts of the city with family and friends - not conspicuous and doing its own thing
The discussion revolves around the use of a DVB-T USB tuner, with the user inquiring about the compatibility of a DVB-S signal meter for measuring DVB-T signals and seeking free software options for Windows XP that provide more than just basic signal strength and quality metrics. Responses indicate that a DVB-S meter cannot be used for DVB-T, and while basic USB receivers can function as signal meters, they typically require specific software for detailed diagnostics. Recommendations include the Digitsat PCM-1210 and TM-600 meters for DVB-T/T2, with additional resources for antenna design and signal measurement software mentioned. The user also seeks guidance on constructing a bi-quad antenna for specific MUX frequencies.
