How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730840 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #1 11180605
    Ganjor86
    Help: 18
    Rate: 46
    Hello, I was looking for news about the SDR radio today because I would like to buy one someday and I came across a topic about SDR reception on a DVB-T tuner for about PLN 60. The case is interesting because the costs are low and you can get some experience with SDR and if you get bored you can have a TV tuner. When the tuner is connected as in normal use, you can receive from 64-1700 MHZ and recently someone came up with the idea that if you connect the antenna to the first leg of the RTL2832 chip, you can also receive short waves! Here's the proof:
    A whole lot of other results Link
    Here is a topic on sp7pki Link
    On this forum someone wrote that direct connection of the antenna to the chip can burn the chip and it would probably be so, but if you used to connect the kf antenna, something like in the 83 post Link
    I think that due to the possibilities and the price, the topic is really worth developing. An additional advantage is that you do not need to use a sound card that is integrated on the computer's motherboard is very poor and the cost of buying a better sound card is greater than the DVB-T tuner.
  • #2 11181248
    Olek II
    Moderator
    Help: 452
    Rate: 414
    Ganjor86 wrote:
    When the tuner is connected as in normal use, it can receive from 64-1700MHZ
    I haven't come across a DVB-T tuner that has a wider bandwidth like 860MHz. Can you provide the model?
  • #3 11181267
    Ganjor86
    Help: 18
    Rate: 46
    Not only LV5T tv but also a lot of others. In the link I gave to the sp7pki forum there is a specific discussion on this topic.
  • #4 11181372
    Olek II
    Moderator
    Help: 452
    Rate: 414
    Technical data
    Not Only LV5T Deluxe tv tuner
    External tuner type
    USB interface
    DVB-T digital terrestrial TV tuner yes
    DVB-C digital cable TV tuner no
    DVB-S digital satellite TV tuner no
    Analog TV tuner yes
    HDTV 720p resolution
    Full cable band
    PAL vision system
    B / G, D / K audio system
    Recording format MPEG 2, MPEG 4
    Analog radio tuner yes
    No input data
    info from the website: http://www.oleole.pl/tunery-telewzyjne/not-only-lv5t-deluxe.bhtml#ixzz22mPQPXK2
    Nowhere does the manufacturer provide such a wide bandwidth. There is a spectrum of terrestrial television everywhere. Above 862 MHz, terrestrial TV does not work.
  • #5 11181413
    Ganjor86
    Help: 18
    Rate: 46
    But if people on another forum managed to get it started like that, maybe I will :)
  • #6 11181455
    Olek II
    Moderator
    Help: 452
    Rate: 414
    I do not deny that it is enough to replace the soft one?
  • #7 11181500
    Ganjor86
    Help: 18
    Rate: 46
    The point is that you install sdr software (many people praise hdsdr) and some basic drivers. I don't know exactly how it works yet, but I will for sure find out :)
  • #11 11182253
    Ganjor86
    Help: 18
    Rate: 46
    And what kind of dongle because I heard that one is not equal to the other. And how with tenderness. Have you tried connecting the antenna to the first or second pin of the IC? Apparently, by connecting the sdr antenna there, it starts working on shortwave, but you would have to think about some protection against some surges. Maybe you try to connect a piece of cable there so that the signal is not too strong? I also know that it is possible to connect a small device to such a tuner that will lower the frequencies on which the tuner works by 100 MHz, i.e. to 0 Hz practically :) and is there an option to quickly make an sdr receiver out of such a dongle and then quickly make an sdr receiver again or does it involve uninstalling the drivers and installing new ones, and so every time he wants to change the use of embedding?
  • #13 11183105
    Ganjor86
    Help: 18
    Rate: 46
    Here Link the modification is described as for inputs below 30 MHz in RTL-SDR
    Added after 13 [minutes]:
    Link here a little more and probably more precisely about the operation of the tuner from 0 to 30 MHz and the problem with electrostatic charge is also described. What if you put a variable capacitor between this pin and the antenna? The distances are probably so large that the spark will not jump, and by changing the capacity of such a capacitor and using a long long wire, it would be possible to adjust the signal intensity :) well up? In addition, one switch and such a tuner could operate in two ranges from 0 to 30 MHz and the other range from 64 to 1700 MHz
    And here at 147kHz
    "This video is no longer available because the associated YouTube account has been deleted." / c2h5oh /
    Well, I have to buy something like that.
  • #15 11230962
    bogi
    Help: 103
    Rate: 244
    Does this scanner work for someone on Not Only TV LV5TDelux?
  • #16 11231376
    Ganjor86
    Help: 18
    Rate: 46
    many people work :) type in google model of your dongle and add rtl sdr and look for the answer :)
  • #17 11231683
    bogi
    Help: 103
    Rate: 244
    After reading the above info, I am going to buy Not Only. But I wanted confirmation before purchase that it works.
  • #18 11393306
    gilong
    Help: 7
    Rate: 20
    and could this system be used as a dds generator? what it has to be treated right? I wonder if it is possible to separate the signal from the generator and connect it to another sdr receiver
  • Unexplained reception gap around 150 MHz
    #19 11594064
    maryjusz75
    I have such a tuner (not only) and confirm its use as a broadband receiver. I'm using it to listen. I only have a problem because I can't pick up frequencies around 150 MHz for reasons unknown to me. And these are what I care about the most (lower - 148 MHz and higher - 160 MHz it catches perfectly). I do not know if it is my tuner fault or some error in the settings. When starting up, I used numerous online tips. Anyone have a similar problem? The next hole is around 300 MHz, but that doesn't bother me.
  • Input protection and NE602 mixer SDR design suggestions
    #20 11594827
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    Gentlemen ... Maybe the name of the system that this receiver is based on?
    Probably leg 1 is the input of the ADC converter (if the IQ demodulation is done by software), and if the hardware is the input of this demodulator, it can be concluded that we are dealing with a typical superheterodyne earlier.
    Security is quite simple. You must first find out what signal levels are there and add either 1 degree on the transistor or possibly give a diode, e.g. 1n4148 from ground to pin and from pin to power, thanks to which we short all electrostatic charges.
    Generally, such a receiver has quite fast analog-to-digital converters, which is its advantage (wide bandwidth of the received signal).
    I personally work out a classic SDR with mixers on NE602 + IF from TV and TV head. It cannot be cheaper and the sensitivity should also be quite decent. The wideband phase shifter by 90 degrees remained to be worked out (solutions on flip-flops fall off because the digital camera is basically only unit jumps with a spectrum that can not occur in the radio)
  • 150 MHz reception gap prompts R820T tuner replacement advice
    #21 11595354
    Ganjor86
    Help: 18
    Rate: 46
    As far as you know, if you have a hole, you can't help it :( If I were you, I'd do this: sell this tuner and buy it on Allegro or even better on ebay, another dongle from the R820T has probably only one hole and a wider range of reception. You can find everything in google.
  • #22 11621245
    Ganjor86
    Help: 18
    Rate: 46
    www.wykop.pl/ramka/1341289/rtlsdr-czyli-odbieraj-niemal-wszystko-z-tunera-dvb-t/
    A handful of information for people not very familiar with the topic, there is also a description of installing the tuner on windows and linux in this link.
  • #24 11654618
  • #25 11654868
    Ganjor86
    Help: 18
    Rate: 46
    www.sp7pki.iq24.pl/default.asp?grupa=3538&temat=136325 see here :) and if you do not find the information you need, ask in this topic.
  • #26 11656731
    bogi
    Help: 103
    Rate: 244
    I also struggled a bit with the installation under XP. Installation condition
    Microsoft .NET Framework 3.5. It also does not work with the higher version.
  • SDR_TEST detects tuner, but SDR remains silent
    #27 11658897
  • #28 11699464
    r03c10
    Help: 10
    Rate: 66
    And I would like to know what antenna is required to receive frequencies other than 88-108 MHz? I would be particularly interested in the 118-140MHz range. My guess is that an ordinary antenna attached to the LV5TZ, for example, is not enough. Or maybe someone managed to pick up something other than the radio on it? I am asking because in SDR # it elegantly receives FM, but in the remaining bands only noise, even when connected to an external TV antenna.
  • #29 11700019
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 658
    This should help with the reception.
    The so-called band TV is not 118-140MHz.
    You can assume that TV antennas have 85% bandwidth above 500MHz.
    Best regards.
  • #30 11719420
    zabex
    Help: 50
    Rate: 52
    Hello. I bought a dongle from the R820T a few days ago and I am pleasantly surprised. On the original antenna I receive FM, air band, ADS-S, NOAA etc ... As these signals are weak, I would like to buy an amplifier like this: http://p.alejka.pl/i2/p_new/42/05/wamplifier -fp-6-l-5-2400-mhz_0_b.jpg and (as I am interested in different bands) to build a Discone antenna.
    Has anyone tested such a solution? How do such antennas work in the case of band reception, e.g. 137-138MHz and ADS-B?
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
