Satlink WS-6906 Meter: Signal Setting & Troubleshooting for Satellite Finder
apepik 12342 8
  • #1 16582197
    apepik
    Hello, does anyone have a Satlink WS - 6906 meter. I sometimes have a problem with setting the signal, can someone answer a few questions? Please contact me.
  • #2 16587057
  • #3 16588543
    apepik
    And what meter do you recommend, this is in the range of PLN 500 - 1000
  • #4 16588585
  • #5 16588591
    misiekpb
    Help: 35
    Rate: 144
    See sat link ws 6933, for amateur use it is enough. Supports dvb s2.
  • #6 16588642
    misiekpb
    Help: 35
    Rate: 144
    Like in a kaleidoscope :) Satlinka on Ali can be bought for about PLN 150.
  • #8 16588651
    pawcio203
    Help: 7
    Rate: 31
    Hello, I used to update my WS-6933 satlink (the first one - with a monochrome LCD) and it works without any problems. After a few years of use, I wanted to load the transponder list via sat edit and here was the problem. The device has a closed port.
    I used to update the firmware and now it's even Polish. Meanwhile, there is no communication with the device. Do you have any ideas?
The discussion revolves around the Satlink WS-6906 satellite meter, with users sharing experiences and troubleshooting tips. The WS-6906 is noted to only support DVB-S, limiting its use with HD transponders. Recommendations for alternative meters in the PLN 500-1000 range include the Trimax TM-8500 for basic antenna alignment and the Satlink WS-6933, which supports DVB-S2. Other suggested models include Megasat HD3 Compact, Spacetronik HW6180, Deviser S30, and Digitsat PCM-1210, all of which are more modern and affordable options. Users also discuss the availability of these meters on platforms like AliExpress, highlighting price discrepancies between local and online markets.
