[Solved] Washing machine Bosch WAE24165EN / 16 - After selecting the program, it displays
jurek54 12603 2
  • #1 17117434
    jurek54
    Help: 7
    Rate: 73
    After selecting any program, the washing machine immediately displays the error code as in the photo below (the LEDs are flashing). What is the fault diagnosis possible? I will add that I am not familiar with the error codes and how to delete them in this washing machine model.
    ROBSON33
    Admin of household appliances group
    Help: 465
    Rate: 1714
    - Drive system defect.
    - Not starting the engine regularly.
    - The engine does not rotate.
    - Program interrupted by critical error *.
  • #3 17118592
    jurek54
    Help: 7
    Rate: 73
    Welcome back. Thanks to the hint of Col. Robson I already knew where to look for a fault. After removing the engine, it turned out that one of the brushes hung. After cleaning and blowing the brush holders, the problem disappeared. Thanks again, Col. Robson. Best regards.
