iPhone 5 Update Loop: iTunes Connection Blocked - Seeking Guidance to Resolve
zygzag 11007 13
How can I recover an iPhone 5 that is stuck in an iTunes activation/lock loop after an update?
The phone needs to be removed from its iCloud/Activation Lock account, then restored in iTunes. Update iTunes to the latest version, connect the iPhone by USB, force it into recovery mode by holding Power + Home until it enters safe mode, and then choose Restore or Restore with Update in iTunes [#16258774] If the device is assigned to an iCloud account, log in to that account on a computer and remove the device there; otherwise the lock will keep coming back [#16271689][#16274039] The thread also points to Apple’s official support procedure for locked devices as the proper recovery path [#16274736]
  • #1 16251408
    zygzag
    Rate: 76
    Hello . I have an iphone 5 (not stolen) which, after being updated by iTunes and playing, shows a message that - Iphone locked the link to itunes. When I connect to Itunes I see a message if I want to manage this phone, if I click so I have to confirm it on the phone which unfortunately displays a message that it is blocked. And so on and on. How to get out of this?
  • #2 16251415
    genuine486
    Help: 20
    Rate: 59
    Have you tried to recreate it? Maybe something went wrong then.
  • #3 16258750
    zygzag
    Rate: 76
    Yes. 3 times and always the same.
  • #4 16258774
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Update iTunes to the latest version. Connect iPhone to PC via USB, press Power + Home and hold, do not release when Apple logo is displayed, wait until it goes into safe mode. Then in iTunes select Playback or Playback with Update.
  • #5 16270046
    zygzag
    Rate: 76
    I did, unfortunately it did not help. The worst thing is that the computer programmer who created the account connected these phones and leaving did not leave any passwords.
  • #6 16270356
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    It's weird, that's how I saved the iPhone recently. Have you had this phone for a long time?
  • #7 16271651
    zygzag
    Rate: 76
    The phone is already a little bit but I have 2 weeks
  • #8 16271689
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    I suspect that it's assigned to an iCloud account, and if someone does not remove it, it will be a meatball.
  • #9 16272303
    zygzag
    Rate: 76
    Well ok, but how to remove it since it is blocked and can not connect neither wifi nor gsm? He is assigned but he is not blocked because I talked with the boss.
  • #10 16274039
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    From an iCloud account, you delete a device by logging in to your account eg with a computer if I remember correctly. Anyway, if it is assigned to iCloud it should be an option just by iCloud to unlock the phone.
  • #11 16274476
    zygzag
    Rate: 76
    OK, but in this case, after unlocking, you must probably update it again via iTunes.
  • #12 16274736
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    I had a few pieces blocked (mostly after incorrectly coded code xx times), I always followed the Apple support guidelines, there was never a problem. Here's the link: https://support.apple.com/en-us/HT204306
  • #13 16428087
  • #14 16428773
    zygzag
    Rate: 76
    Now, I can only send a photo of the trash can because it landed there.
The discussion revolves around an iPhone 5 that is stuck in an update loop after an iTunes update, displaying a message indicating that the device is locked to iTunes. The user is unable to manage the phone through iTunes due to the lock. Various suggestions are provided, including updating iTunes, attempting to enter safe mode, and checking for iCloud account assignments. The user expresses frustration over the inability to unlock the device, as it is blocked from connecting to Wi-Fi or GSM networks. It is suggested that the device may need to be removed from the iCloud account via a computer, and that following Apple support guidelines could help resolve the issue.
